is my turbo gone????
driving today car worked perfect i got into traffic and started noticing a soft howling noise then by the time i got home its very loud and i got no boost????
link to what is sounds like
http://s261.photobucket.com/albums/i...0929-00003.mp4
that piece should be solidly attached. It's probably broken, which would explain the boost leak. If you want, take that off, and fill the hole with JB weld. It's just there to collect condensation, it's not necessary, they break all the time.
ya you scraped and knocked that piece loose. turn the car on and check around where it connect to the end tanks......you should be able to feel a little air coming out somewhere if the leak is big enough its causing you to not build boost. you can just patch it if its not too bad.
Judging by it looking as though you hit an elk from the looks of your bumper, I'd say check your intercooler. Def sounds like an end tank blown apart. Too whirry and loud to be just a small boost leak like charge piping unless it completely came off. My boost leak sounded like a bottle rocket but I found later that it was a coupler that had a 3/4" hole cut in it.
VID-20110929-00003.mp4 video by domestic_rice - Photobucket
An impact of some sort, at some point caused that bottom piece to break off (for me this was daily driving in winter). This happened to me as well and the part was like that for close to 4 months, though.. when it "broke" I was just driving down the road normally. I lost boost pressure, the culprit was the end tank being blown off, as a result of the entire weight of the part hanging down and moving, putting allot of pressure where its attached at the other end.
Warranty covered it, but by the looks of your car... it seems like its been ran into a wall or two - so they might call shenanigans.
this happened to my brothers srt-4, the turbo was gone, the fins in the turbo were shredded and it would build boost, stupid dudes at the dealer let crap get into the turbo and didnt block it off
Didn't this happen to someone on here when a piece came off the inside of the intake and got shredded in the turbo?
P.S. OP, keep you eye peeled on the Classifieds section on this site. I picked up a spare K04 for only $200 with very low mileage.
