My Turbo turned into a Supercharger
Cruising down the road like a normal.. Turn down my dirt road and go 15 mph and I get into my drive way and start revving my car not to bad only to like 3k just cause I love the noise and The first rev sounded like a ******* supercharger... I go down to my neibors driveway (payment) and do a second gear pull and I HAVE NO BOOST AND MY CAR WHINES LIKE A BISH! I took off the upper charge pipe and there is no oil at the bottom of it going into the intercooler.... There is a little bit at the top of the charge pipe right where it starts at the flexible piece and where the upper cp connects to the turbo.. not to much but enough to get on my finger... I have a soccer scrimmage in 1 and a half... is it okay to drive it very easily??
Don't they usually blow smoke out the tail pipe is it's the turbo seals? You sure you don't have a major boost leak and you aren't hearing the turbo? It's super freaking loud. Ask me how I know.
almost as epic as your lsj man. your the biggest piece of **** I know. I have soccer in a hour and need to know what the **** is wrong with my car. Not giving a flying f about spelling your a lsj get the **** out of the lnf category you piece of ****. I need information not replys from a dbag like you hahahaha like does that make you feel better? god your a ******* idiot.
white smoke was coming from the exhaust... and im not pushing over 0lbs....
white smoke comes out the exhaust when i rev... sounds like a sc not really like one but sounds like a sc more my damn turbo.. I dont go over 0lbs of boost and my vaccum is at like 12 untill i start to go then it goes back down to 20..
OP, jack up your car real quick, look at the bottom of the intercooler, see if theres a metal condenser there or if it looks like anything pushed up on the intercooler. Also check the lower charge pipe, make sure its connected on both ends.
no just need answers... im varsity captain and this coulld be a bad look for me...
1.. white smoke when revving
2... dont go over 0lbs
3.. supercharge noise more then turbo noise.. even in reverse.
4... took of the charge pipe and there is oil where the charge pipe connects to the turbo.. enough to get some on my finger a couple times...
5.. no oil where upper connects to intercooler.
White smoke could be coming out of the exhaust cause you worked the turbo to death with a big ass boost leak. Check for busted/loose ****!
