Need Bore Spacing for LNF
Old 09-26-2013 | 03:01 PM
rrkroll's Avatar
HI,
I am in the process of doing some headwork on my LNF, I have measured the bore spacing and think it is 96mm, does anyone know if this is exact?
Thanks
Old 10-03-2013 | 06:51 AM
hucks1987's Avatar
Bore spacing??? the bore on the LNF is 85.992-86.006mm or 3.3880-3.3887inch
And if your talking about vavle bores its Exhaust/intake 6.000-6.012mm or 0.2362-0.2367
If you go to the top page of the LNF Section and the top Sticky All the LNF Specs are there
Old 10-03-2013 | 07:49 AM
noorj's Avatar
bore spacing is the distance between the center of the bores, machine shops need this to hone blocks correctly
Old 10-03-2013 | 04:27 PM
cmiller8006's Avatar
A good machine shop will have the ties to get that info. My guy uses a 5 axis cnc machine that you just bolt the block in and program the block and it does the rest.
06MetallicBalt
08-17-2021 03:40 PM
Zharrington_2010LNF
02-08-2016 01:43 PM
HEATON
10-16-2015 07:21 PM
10-13-2015 09:32 PM
patooyee
10-01-2015 01:07 PM
Quick Reply: Need Bore Spacing for LNF
