In need of a tuner
In need of a tuner
Hello all, I have been a member here for a while since buying my TC and normally keep quiet and just stalk the forums but I'm currently looking for a retune on my TC. I'm from the Pittsburgh area and am looking for a dyno tune from any reputable tuners around the area. The car currently has these mods:
- AEM intake
- Injen Upper Charge Pipe
- ZZP catless downpipe
- Hahn Catback
- HP tune
The reason I am looking for a retune is because when I got the original tune the car was given a tune from the tuner's solstice GXP and he didn't have time to datalog it. Also since then I have gotten the tune I have added the downpipe and upper charge pipe so it needs a retune anyways. I know that the AEM is the most temperamental of all the CAI to get the AFR right and before the tune I would probably switch to the K&N SRI. The car runs decently enough recently I ran a 13.36 at 105 on drag radials, not incredible for that set up but I know theres more in it in terms of driver mod (only a 2.02 60') but I also know that with a proper dyno tune that is specifically dialed in for my car would also help it out. Any knowledge of a reputable tuner in the area would be appreciated. Thanks in advance.
- AEM intake
- Hahn Catback
- HP tune
Thanks guys for the responses sorry I couldnt get back sooner, Ive thought about getting HP tuners and doing just that but I'm not exactly sure how it works. The credit system scares me a little, do you use the credits as a one time thing to tune the car unlimited times? Or do you need credits every time you go back in and tweak it? I would be fine if it was a one time cost but if you have to keep buying credits on top of an already pricey software I'm not sure if thats what id want to do
Ok thanks all for the help, I'm definitely a noob when it comes to everything tuning wise with our cars. Im LNF so luckily i get to spend less money haha. All i need now is to save up for it. Again thanks for all the help
get the intercooler first it'll be woth it then get the tune you'll be more happy, your stock IC tends to break/leak under higher boost plus it can't keep up in cooling the air once you start pushing more boost/ making more HP I have a treadstone tr8 it made a big difference, plus this way you can account for pressure drop of the IC now instead of worring about it later
