New Rear TC Rotors
#57
Just letting you guys know, we been having a GB/ member discount for quite some time now. Here is the link you are interested, PM me if you have any questions:
https://www.cobaltss.net/forums/show...84#post3136784
#61
#62
front rotors:
315mm diameter
26mm thickness
(out of stock, give another 2-3 wks)
rear rotors:
292mm diameter
20mm thickness
(available, Premium series only)
Thanks
Steven
#64
If that's correct and you're able to cross-drill and/or maybe slot them, post it up. People would probably go crazy over it since nobody offers cross-drilled for instance and the slotted ones on another site are pretty expensive.
#67
Holy **** this is awesome news. The more I read though, the the more I want drilled...both front and back!
#70
I'm just full of questions now.
#71
Eline series rotors are the ones with silver zinc plate and standard iron cast g3000 metal material like your originals. Premium series rotors are cast with even stronger iron casting materials and comes with a black E-coat rust protection coating only on the center hub and inner vane structure and outer rim of rotor. These are considered my flagship rotors (best, heavy duty).
#73
