New Rear TC Rotors
Old 11-14-2009 | 01:26 AM
  #151
XStylus's Avatar
Originally Posted by interviewatruins
i just got an 09 tc, what should i look out for with the rears?
I just bought an '08 TC with 125mi on it two weeks ago. Odo now reads 1800mi and the rotors (including outside surface) look like a DJ record and squeal like nails on a chalkboard.
Problems with the rears have been well reported around here on most '08s and some '09s. Unfortunately Chevy won't acknowledge any problem, so warranty coverage has been like pulling teeth.
Knew this was going to be a problem before I bought the car so I already have money set aside for improved brakes and rotors. I just want to make sure that by replacing pads and rotors I will indeed solve the problem, and that the calipers aren't an issue. Some have chimed in and said caliper pins have insufficient lubrication and that the inside pad wears unevenly and prematurely.
Old 11-14-2009 | 02:30 AM
  #152
HB_SS/TC's Avatar
Well I've got about 4,000 miles on them now and still no signs of grooving or anything like that
Old 11-14-2009 | 02:46 AM
  #153
Steven Flit's Avatar
Just lube up the sliders on the rears if they dry and that's the case.
It's only 2 bolts holding the top portion of the caliper on. 18mm, or was it a 16mm... meh
Old 11-14-2009 | 03:01 AM
  #154
lifeguard15's Avatar
Couldn't be happier with my R1 Concept rear rotors and Hawk HPS pads. Great looking, and judging from others' experience, they should hold up great.
Old 11-19-2009 | 11:52 PM
  #155
XStylus's Avatar
You still running stock rotors on the front? Any issues with brake bias?
Old 11-19-2009 | 11:55 PM
  #156
HB_SS/TC's Avatar
My front rotors are in my trunk right now in need to put them on
Old 11-21-2009 | 06:04 PM
  #157
sherm420's Avatar
ive drivin over 6k since and literally smooth as butter
Old 11-24-2009 | 01:04 PM
  #158
julius41282's Avatar
What pads are you going to use for the front?
Old 11-24-2009 | 01:14 PM
  #159
HB_SS/TC's Avatar
Probably stock ones
Old 11-24-2009 | 01:17 PM
  #160
Do you know if anyone has tried the HPS pads on the front?
Old 11-24-2009 | 01:22 PM
  #161
elecblue06's Avatar
someone needs to mean a rear dust shield to actually help you guys out.. has anyone looked at using the ones from the sky or solstice and modifying them? thats whats killing your guys rear brakes the **** getting in between the rotor and pad
Old 11-24-2009 | 01:37 PM
  #162
Iam Broke's Avatar
No dust shields and no issues with Hawk HPS rear pads after ~18k miles now. It's the factory pads.
Old 11-24-2009 | 02:04 PM
  #163
elecblue06's Avatar
the factory pads are a soft compound if i remember .. which is further exacerbated by the fact that there is no dust shield
Old 11-24-2009 | 08:02 PM
  #164
MaxVQ35DE's Avatar
You're funny
I want to have both ECMs reflashed + Trifecta tune on top of the stage kit
cant do it.
there is only one authorization code and download, youd have to buy 2 stage kits
Old 11-24-2009 | 08:25 PM
  #165
HB_SS/TC's Avatar
Originally Posted by MaxVQ35DE
cant do it.
I found that out but there's another way of doing it
Old 11-24-2009 | 08:30 PM
  #166
MaxVQ35DE's Avatar
robbing a parts department?
Old 11-24-2009 | 08:35 PM
  #167
HB_SS/TC's Avatar
I don't know but Vince has a way
Old 11-24-2009 | 09:50 PM
  #168
emiller's Avatar
My inside pads and rotors just got grooved like crazy and started suddenly squealing like it was metal to metal not the normal cold brakes. Must have gotten some junk in there or something but I wasn't about to take the wheels off in the rain for a closer look. Pads were about 1/2 worn inside and outside at 22.5k miles.
Either way dealer replaced the pads and rotors under warranty no questions asked. Took 3 business days to get parts.
01-12-2016 01:01 AM
DANRICKARD
10-01-2015 01:08 AM
Delta coupe
09-30-2015 09:11 AM
09-27-2015 09:53 PM
grampss
09-27-2015 09:51 PM
