New Rear TC Rotors
#151
Problems with the rears have been well reported around here on most '08s and some '09s. Unfortunately Chevy won't acknowledge any problem, so warranty coverage has been like pulling teeth.
Knew this was going to be a problem before I bought the car so I already have money set aside for improved brakes and rotors. I just want to make sure that by replacing pads and rotors I will indeed solve the problem, and that the calipers aren't an issue. Some have chimed in and said caliper pins have insufficient lubrication and that the inside pad wears unevenly and prematurely.
#161
someone needs to mean a rear dust shield to actually help you guys out.. has anyone looked at using the ones from the sky or solstice and modifying them? thats whats killing your guys rear brakes the **** getting in between the rotor and pad
#163
#164
#165
#168
I just bought an '08 TC with 125mi on it two weeks ago. Odo now reads 1800mi and the rotors (including outside surface) look like a DJ record and squeal like nails on a chalkboard.
Either way dealer replaced the pads and rotors under warranty no questions asked. Took 3 business days to get parts.
DANRICKARD
10-01-2015 01:08 AM
Delta coupe
09-30-2015 09:11 AM
