No boost after installing CAI
Old 07-19-2013 | 12:19 AM
MyMidNiteMoment's Avatar
hi i'm new here so be gentle lol. I recently installed an Aftermarket cold air intake. (not even sure of the brand might be spyder) and it was running fine for a few hours and then on a trip to the store my engine lights came on and now my turbo sometimes doesn't want to gain boost and randomly it will start to gain boost. Any suggestions on how to fix this? I'm assuming I just need a tune but I am not sure as for i'm slightly noobish.
also if this helps its a 2009 cobalt SS/TC all stock minus the CAI
Thanks! =)
Old 07-19-2013 | 12:21 AM
1. Get your codes read(free at autozone)
2. Post codes here in original post(that one^^)
3. One of these homos will help you
4. Goodluck
Old 07-19-2013 | 12:30 AM
06cobaltncng's Avatar
4. Goodluck
best answer ever.
Old 07-19-2013 | 12:32 AM
4. Goodluck
At least you already got #3 taken care of
Lol
Old 07-19-2013 | 12:49 AM
well I would go to auto zone but im Canadian lol...
but ill get it checked out in the next few days
Old 07-19-2013 | 12:52 AM
most car shops, least round here, will read codes free as well.
Old 07-19-2013 | 01:38 AM
I'd almost bet its unrelated to the CAI, but it could be. Might want to think about purchasing the torque adapter for andriod
Old 07-19-2013 | 01:42 AM
SalvageBaltSS's Avatar
ya same here, then they like try giving you quotes, and tell you how good there shop is, and that they only charge you 80 dollars a hour!
Old 07-19-2013 | 01:53 AM
Fastgti69's Avatar
Make sure you put the MAF in the correct position with the arrows.
Old 07-19-2013 | 01:55 AM
serega12's Avatar
Torque app is awesome. And adapter is only about $15
08ssedan's Avatar
Did you check to make sure the coupler is on tight?
Old 07-19-2013 | 02:26 AM
Welcome to the site.
Old 07-19-2013 | 02:42 AM
buildmeanempire's Avatar
Yep. I'd say after using mine that it is a must have for anyone. I've only had mine a couple months and I've used on all 3 of my cars. I don't use it everyday but when I do I'm glad I spent the $30 I did. Best investment so far.
slapbetcommissioner's Avatar
I'm assuming if the intake through off the fuel trims bad enough the car would go into reduced power mode?
What intake? And yes it matters which one haha.
Old 07-19-2013 | 03:54 AM
Cobalt_SSTuner's Avatar
1. Check the little arrow on the MAF
2. Check all the couplers
3. Get the Code Read
Old 07-19-2013 | 11:04 AM
tomj77's Avatar
I'd vote u didn't plug in ur maf. U can't install maf backwards, bolt pattern doesn't allow it
Old 07-19-2013 | 11:05 AM
Fastgti69's Avatar
You sure?
Old 07-19-2013 | 12:17 PM
tomj77's Avatar
Well seeing as iv tried installing one backwards on 2 different intakes just to see, and the bolt holes didn't line up and u couldn't put one of them in, I'm pretty sure.
Old 07-22-2013 | 04:20 PM
10CSSTC's Avatar
This is the answer. I had this happen to me with an intake. The air was so jacked up flowing over the MAF that it caused limp mode several times. Took that garbage off and threw on a KNN sri.
OP. Take your intake off for a day and i bet your problem goes away. Take the intake back, get a refund, then buy a KNN SRI
turbochargedss2012
09-20-2023 01:17 PM
01-12-2016 01:01 AM
deviance
11-24-2015 06:51 PM
justinchinn
10-02-2015 01:18 PM
09-27-2015 09:53 PM
Quick Reply: No boost after installing CAI
