o2 sensor.
Old 03-29-2010 | 12:11 AM
tomj77's Avatar
o2 sensor.
Well my o2 sensor is shot. keep getting o2 sensor stuck lean code. so i ordered a new one.
I was standing in the plumbing section of a hardware store the other day and was thinking, why not take some cast plumbing tubing and such and screw em into the o2 sensor port and more the sensor possition up to the top of the engine where it can be easily reached and where it is out of the direct heat of the exhaust. it wouldnt take much to do. what do u guys think? would it work? i think im gonna try it see what happens.
Old 03-29-2010 | 12:13 AM
slowswap's Avatar
If this is the primary O2 sensor, a huge NO. It needs heat to properly work and for accurate readings, it needs to be in the stream.
If this is the secondary O2 sensor, which has nothing to do with a lean code, then use a spark plug antifouler.
Old 03-29-2010 | 12:20 AM
badbaltguy's Avatar
where did u find the o2 sensors at cuz i'm in need of 2 new ones, i looked on gmpartsdirect and i cant find them on there, im trying to avoid having the dealership order them cuz i need them ASAP.
Old 03-29-2010 | 12:22 AM
tomj77's Avatar
ya its primary hince the code i guess. so then ill just change it and leave it. when i get the code my car sputters and idles rough. so im sure its primary.
Old 03-29-2010 | 12:23 AM
slowswap's Avatar
Lean code could be just a bad sensor, or a vacuum leak.
Old 03-29-2010 | 12:28 AM
tomj77's Avatar
im sure its the sensor, cause i get random misfire at startup sometimes to. it says 02 sensor (bias) stuck lean. and its slowly getting worse with the code, its only at startup, when driving it doesnt seem to throw it.
Old 03-29-2010 | 01:27 PM
cardelino18's Avatar
Originally Posted by badbaltguy
where did u find the o2 sensors at cuz i'm in need of 2 new ones, i looked on gmpartsdirect and i cant find them on there, im trying to avoid having the dealership order them cuz i need them asap.
x2!!!!!
Old 03-29-2010 | 04:32 PM
Stamina's Avatar
Front WB02: 12589380 $58.61
Back 02: 12616506 $35.99
Both are on GMPartsDirect... gotta look under the electrical section though.
NJHK
Forced Induction
40
02-21-2019 01:50 PM
Tupp
2.2L LAP Performance Tech
01-02-2016 01:04 PM
royce777
09-28-2015 08:11 AM
NJHK
08-08-2008 02:50 AM
nybull05
05-23-2007 08:14 PM
