Oil in Exhaust: Smoking..
Recently car has been having oil within the exhaust, smokes after driving for 5mins..
I have changed the pcv still same thing happens, next step is to clean charge piping & fmic.. Friend did a compression test for me while I was out of town said it checked back on 180 all around?? Idk I'll end up doing my own shortly.
Car drives fine and boost fine, no weird noises if I drive a tad bit harder than normal crusing it smokes earlier and more..
What could it be? I've been told cylinder head, turbo seals & injectors..
Yes check all of your piping and FMIC for oil. Take your intake off and check the turbo for shaft play.
If you don't find an external oil leak anywhere, lines etc, then you most likely have a turbo seal problem.
Swapped out gaskets still smoking, going to use brake cleaner and pull off charge piping to clean any oil within it...
Checked plugs no oil on them.. 🤔
Not sure what else to do.. Maybe oil connector out wrong place after motor was put back together..
yellow_cobalt
04-03-2016 10:20 AM
