oil galley plugs on ldk
Oil pressure gauge on the back port of the head will read less at idle then of its on the block. Ive had this happen on 3 dofferent cars where using the back port on the head is the only option
Personally just use the mil light. Most of the time by the time you look at the gauge and your oil pressure is reading that low its to late.
everything I found is the same technical info u can find on google. when I get mine Ill do a comparison like ports and such. if u look at the block on pics, the ldk looks very bare compared to lnf. like they took out everything that's not needed.
