One last problem on the rebuild
I recently put new pistons in “wiseco forged” and got everything put together she runs great just can’t for the life of me figure out this pcv system been all over the forums I tried to make it close to stock as possible but she runs really ruff when I actually connect the pcv valve to the intake piping where it normally goes and add this piece I made to have the 2nd port installed for the vacuum puller side the car runs like ****, when I keep it like in the picture how it’s hooked up now she runs fine but tosses the Maf code, i didn’t want to weld in a fitting without testing on a silicone tube first, anyone got any ideas to help make her run better with the pcv system hooked up correctly, anything helps. Also car has a precision turbo 58mm and was tuned in this set up a long time ago. I am trying to set up a new tune but want to fix this last thing before I set an appointment. I don’t know if the two lines were too close together or if the vacuum line needs to be closer to the turbo, but I don’t want to weld or destroy any piping unless it’s going to work correctly, I understand how the system works at least I thought I did “air goes in the pcv valve down to the crank and sucked out through the top back into the intake” I might be wrong but that’s what it looked like when the head was off..
This is how I have it connected now with the port on the valve cover going directly into the normal pcv connection line.
This is the piece I made where I installed the port in the first picture too then put the pcv valve onto its original port. It was jb welded before I destroyed it taking off the hose.
when I leave the pcv valve just unplugged car runs great minus the maf code that pops up...
Big turbo pcv system. You came to the right place. Now. Did you put the line from the port closest to intake on valve cover as close to the turbo inlet as possible? In the coupler? Is that what I'm seeing here? What did u do with intake manifold circuit ? Left stock?
I didn’t want to weld in a nipple on the pipe close to the turbo so I made that silicone tube and it was installed right there in the pic. Also left it stock. I can place it closer to the turbo but would require welding and if the port closest to the intake need to be closer to the turbo I can try that after I replace the intake manifold pcv valve
Yeah I had it set up like that but it was only about 6inches apart from the normal port and I cleared the code started her up drove around the block and she was idling really bad and sounded horrible so I parked her n took it off, this weekend I’ll try and put it closer to the turbo instead of the flange there..
also might by my tune causing the issues because cause she was tuned with this system fucked up after I installed the turbo without the pcv air in connected. No codes until I put in forged pistons head valves springs n everything, I just didnt think a pcv system was so fkn critical on this car.. did my research and yet still here, I’ll take some videos if she still running ruff.
Im going to replace the intake manifold pcv and I bought a mishimoto flange with a bung for the vacuum and clear all codes and drive her around again, most likely on Friday or Saturday I’ll give an update, I have a oil catch can to set up once this is all fixed to route from valve cover to turbo but haven’t set that up tell it’s working correctly. Not trying to fk up my new valves too..
if you don't wanna screw up ur valves with gunk, you will have too do a catch can on the manifold pcv as well. that's where most of the oil gets on the valves from.
