PCV line from air intake to valve cover
Old 06-06-2019 | 05:50 PM
Keith-SS's Avatar
I’ve been reading a lot on the forums about getting oil spray in the intake tube. I have a K&N Sri and get oil in it and it soaked the bottom of the filter in the past 6k miles. I pulled the line off and is that a one way valve on the braided line? Cause I can get air to pass through both ways. I don’t want to replace it with the revised line if I don’t have to and don’t have enough funds for the Powell oil/air separator at the moment.
I already replaced the one in the manifold when I did a valve cleaning job because it was a cheap replacement and was already in there.
Old 06-06-2019 | 06:02 PM
exninja's Avatar
The line that goes from the VC to right behind the airbox DOES have a check valve, the one that goes from the VC to the compressor of the turbo does NOT have a check valve. If the valve in the first line allows flow both ways, it needs to be replaced. That is the fresh air inlet.
Old 06-06-2019 | 06:36 PM
Keith-SS's Avatar
Thanks for the quick reply. I seen the flow arrow on the valve and was afraid of that. I guess I’ll have to order a new one.
dgascho
09-27-2017 09:48 PM
Dustin24
09-30-2016 06:11 PM
Wangspeed
06-26-2012 10:50 AM
06black$$
06-13-2012 09:57 PM
Gimpster
03-14-2011 11:04 PM
Quick Reply: PCV line from air intake to valve cover
