please please please help what to do
You have multiple issues.1st the p0497 is low purge flow,easy fix is replace purge solenoid.Very common failure on sstc. The other 3 codes are for ur o2 sensors. p0130 is closed loop performance sensor1.p0036 is sensor 2 heater control circuit.p2270 is sensor2 stuck lean.Its very unlikely that both sensors tooka dump at the same time not to say it cant happen. I would check the wiring under the hood and under the car for obvious issues like burnt or broken wires and check the fuses for the sensors. If you dont see anything obvious go to the dealer.Possiblity both sensors failed,wiring issues or pcm failure. Have seen 2 hhrtc and 3 cobalttc come threw the shop with o2 issues due to pcm failures. Hope i helped ya out some
