PO101 not quite
Old 11-16-2015 | 11:12 AM
Ohio SS/TC's Avatar
PO101 not quite
Only threw the code once, its a code that always ends up as a pending code. 2008 SS/TC. Randomly will only boost to 5psi. If I hook up actron scanner and clear pending codes while driving it will boost up to about 15psi again. < which I believe is normal. Only does the underboost underpowered stuff occasionally. Like I said clearing codes seems to make it work fine again.
-K&N typhoon intake with spectre filter. Stock charge pipe I believe (black plastic)
Old 11-16-2015 | 11:25 AM
That codes tends to mean you have a boost leak. Reason why your only boosting to 5psi
Old 11-16-2015 | 11:35 AM
Ohio SS/TC's Avatar
If I had a leak wouldn't it not be able to reach full boost for a majority of the time. I can drive it 2 days without a problem, then randomly it will go into that limp mode....untill I clear the pending code.
Old 11-16-2015 | 11:41 AM
You probably have a small leak reason why it's pending and not setting off
Old 11-16-2015 | 11:45 AM
Ohio SS/TC's Avatar
Damn, guess it's time to get busy with boost leak testing....aslo it rough idles occasionally too
Old 11-17-2015 | 05:21 PM
Ohio SS/TC's Avatar
I made the boost leak tester. I just got done testing, the system seems to be holding pressure just fine and the only place I can hear a tiny tiny bit of air coming from is the hose off of the engine for the PCV valve where I disconnected it from the intake.
Old 12-05-2015 | 01:12 AM
Ohio SS/TC's Avatar
I replaced the MAF just to get that out of the way. Code still comes back in the pending. I clear it before it actually shows up on the dash. I hate driving in limp mode. When its cold and starting the car it sometimes has a missfire till it warms up a bit. Idk if it's related or not. This is driving me nuts as I have to keep the DTC code eraser in the car at all times when I'm driving.
Old 12-07-2015 | 05:24 PM
umrdyldo's Avatar
If you have an 08 and you have never cleaned the intake valves, you will likely be experiencing misfires that you can feel in the seat at cold start.
Old 12-09-2015 | 01:24 AM
firehawk618's Avatar
The other negative to constantly clearing your codes is your fuel trims will never settle in. Every time you clear the codes your trims start back at zero. Not a big deal if you're bone stock though.
The other day I did a bunch of work to my car, had the bumper off, disconnected a bunch of boost pipes etc.
Got all done, went for a drive, 5 miles away from home I finally got on it and POP off came a boost pipe.
Zero boost of course and after I got to my destination and re started the car it threw the P101 just like you.
I also would lean toward a small boost leak.
Old 01-15-2016 | 02:29 PM
Ohio SS/TC's Avatar
No boost leak, but noticing that my LTFT hangs around +20-21
Old 01-15-2016 | 03:03 PM
umrdyldo's Avatar
Ok lets talk about this, your LTFT is unacceptable.
+- 5 is ok. 10 is not good but is fine short term.
20 means you need to fix your ****.
If running stock or GMS1 you should see +-5%.
Find your boost/air leak.
Have you taken off the bumper and inspected the intercooler.
Old 01-15-2016 | 03:52 PM
Devin86's Avatar
Check your bypass vavle I had a p0101 issue like 2 years ago threw a forge in and it stopped.
Old 02-21-2016 | 11:30 PM
Karnage's Avatar
I also have the same problem with my car , did you find the fix?
Adecker
05-16-2016 08:12 PM
'05SSSC
12-04-2015 01:52 AM
axmonkey
23
11-17-2015 06:47 PM
tomj77
11-17-2015 01:55 PM
CobaltSSTC
11-11-2015 10:30 PM
