Psykotuned LNF
#651
#653
Working on a Northeast location and date. Not sure yet.
And Brawn!
And Brawn!
#654
I have no doubt that waffles are delicious and flapjacks are evil. Formed in the shape of the eiffel tower makes me question how deliciousness holds up to structure. I, therefore, must try this. Maybe even compare it to a waffle pyramid!
#659
yeah, in this thread too :ninja sneak:
This weekend on a Dynodynamics dyno (reads low numbers) and on 91 octane, and with RWD Solstice and Skys we made an impressive....................
275rwhp and 320rwtq. That's roughly 332hp/387tq at the crank. And the peak hp didn't last 200-400rpms like it does stock, it held for 1,300rpms!
My SS/TC number are much higher than what I have been posting. The posts are for RWD cars. I have some of TOMs dyno pulls, but I will also have more after this weekend in Houston.
#662
updates don't cost anything bud. im down at modified right now.
in all fairness. steve sent me a base file to work from. well i did work from it. however, i put my personal spin. well, thats what you get. simple timing and fuel work. then some secret sauce.
#666
Mine was also set for higher temps and 91 octane. I got 275/320 out of the RWD cars in better weather this weekend. Also the tune I sent AREA was from before dyno tuning it, and mine was a lot better afterwards.
#667
91 degree's on the rollers saturday.
95+ iat temps.
if you want me to pull a dick move, i can. the middle numbers came from the map you sent me. people wanted to see dyno numbers of your tune. so i gave it to them.
95+ iat temps.
#668
Our IAT temps were 135+ when I tuned my setups so I had to pull a lot out of it. No dick moves, you just did a good thing by customizing the tune like I do when I get any car on the dyno.
#670
You have to run the car while it's hot believe it or not, because when the exhaust is cold you will make less power. And Direct Injection loves the heat. I am sure AREA saw similar things happen when he was running Duke's car this weekend.
#671
i was just wondering....
i dyno end of october i will have intercooler + piping....
i get 3 pulls.... ima dyno ures and I got 2 other tunes.... see which 1 puts out the most
ohh yea i raced a stock t/c like mine from a roll with your tune... beat him by like 3 car lengths from 40-95.... car pulls hard forsure
#675
Ah, I used SAE.......doesn't STD read higher numbers? Still gives you a good comparison though on AREA's graph since all are with the same factor.
