Rebuild f35 or swap it with another? 4.45 gears
John just said the second gear locking ring was destroyed. Stock suspension other than cm lowering springs. It has worked fine for me so far and has done good, somewhat.
this is coming from a tuner. Very familiar with our cars too. By high boost canister you mean an obnoxious amount of boost? I only plan on going 25-26psi max and with a nice boost ramp to get me there. So it won't come in full force. Plus I'm not an idiot that nls, downshifts at high rpms, and floors it at 2k xD
Yes but yours is damn near 450whp on 93 and 28-29psi. Sounds like the OP is going to be making quite a bit less boost and less HP and torque so I think he will be ok for quite a while especially if he is not a mad man behind the wheel.
thanks man I appreciate the good info! I'll hold out on replacing the clutch until it starts slipping. I figured I'd leave the funds set aside if worst case happens. In the mean time I'll just leave my stock tranny and clutch in. I appreciate the info! Thanks again!
ionRL_585 (05-21-2022)
#38
for you and sam as far as I know you have both been replied to. Recent family emergencies had slowed down about everything except for must ship items the past few weeks. Sam has the results and photos. As far as I know you were replied to in detail by me WFF. Dont hesitate to speak up or email me if I have missed anything for you.
#39
It is on topic to say it here I suppose, but with no particular person or transmission in mind, consider this for transmission longevity:
Standard Cobalt manual trans engine mounts along with tire pressure and tire construction, and violent side stepped clutch launches can lead to power hop; worn suspension makes it worse. Rotated mounts help cancel power hop.
Powerhop will break an F35 faster than you can say....F35.
Mismatched shifting is something else that can also break a transmission,..
Many folks think that if the wheels are spinning you dont have power hop, They are partially correct, but at onset of the spin or as you trail off the gas to unspin , power hop can briefly occur. In the rain, power hop is brutal. Its up to the driver in this instance to be sensible.
It is also clear to me ( I drive Delta a lot , and own one) that folks dont always get the clutch all the way in to shift. I find myself doing that, and as the clutch pedal rod and ball socket wears, and the firewall master cylinder bracket breaks ( on 04-07 delta) the resulting "clutch not disengaging fully" is an issue.
And there is not rev matching on the down shift. Fully 90% of the folks on here do not appear to have a clue about this technique or understand its importance.
So I am saying that impacts to the transmission, caused by not rev matching on the down shift are not at all good.
This is because of the resultant torque multiplication, due to forcing the second gear synchro into having to match engine speed to vehicle speed ( 3200 lb car) etc. It is all too much for the trans to handle and you can exceed trans torque capacity in a way most of you have probably not considered.
It is also possible for "reverse" power hop to occur on a mismatched down shift. NASCAR race cars, and Gen 3 Camaro , (two examples), get rear axle hop on mismatched downshifts. Oftentimes the trans on the NASCAR cars or the diff lets go. On the Camaro the trans, the C beam and the diff would break , take your pick. Cadillac CTS V 04-07 also the same thing.
So the talk on here by the folks who know about `driver mod`? Right on
#40
It is on topic to say it here I suppose, but with no particular person or transmission in mind, consider this for transmission longevity: Standard Cobalt manual trans engine mounts along with tire pressure and tire construction, and violent side stepped clutch launches can lead to power hop; worn suspension makes it worse. Rotated mounts help cancel power hop. Powerhop will break an F35 faster than you can say....F35. Mismatched shifting is something else that can also break a transmission,.. Many folks think that if the wheels are spinning you dont have power hop, They are partially correct, but at onset of the spin or as you trail off the gas to unspin , power hop can briefly occur. In the rain, power hop is brutal. Its up to the driver in this instance to be sensible. It is also clear to me ( I drive Delta a lot , and own one) that folks dont always get the clutch all the way in to shift. I find myself doing that, and as the clutch pedal rod and ball socket wears, and the firewall master cylinder bracket breaks ( on 04-07 delta) the resulting "clutch not disengaging fully" is an issue. And there is not rev matching on the down shift. Fully 90% of the folks on here do not appear to have a clue about this technique or understand its importance. So I am saying that impacts to the transmission, caused by not rev matching on the down shift are not at all good. This is because of the resultant torque multiplication, due to forcing the second gear synchro into having to match engine speed to vehicle speed ( 3200 lb car) etc. It is all too much for the trans to handle and you can exceed trans torque capacity in a way most of you have probably not considered. It is also possible for "reverse" power hop to occur on a mismatched down shift. NASCAR race cars, and Gen 3 Camaro , (two examples), get rear axle hop on mismatched downshifts. Oftentimes the trans on the NASCAR cars or the diff lets go. On the Camaro the trans, the C beam and the diff would break , take your pick. Cadillac CTS V 04-07 also the same thing. So the talk on here by the folks who know about `driver mod`? Right on
#42
#45
#46
I'll take your word on it. Powells stage 1 kit is actually cheaper than both tranny mounts zzp requires as well. And I know john is known for his great work with suspension. I will certainly be purchasing the stage 1 tranny mount set up from him. Might give my stock tranny a try with the zfr and see how she holds. Assuming my clutch goes i just got a hell of a deal on a clutch set up so I already have that and regardless of what gears I go with they all work with the clutch.
ThoR294
10-04-2015 09:44 PM
