replacing clutch disk
Old 08-10-2016 | 09:46 PM
tomj77's Avatar
so while my cars apart and the clutch is sitting there I was thinking, why not put in a new flywheel and clutch disk? mine has seen some abuse but still has a decent amount of material left, but new will last longer. question is, do u resurface the pressure plate or just leave it?
Old 08-11-2016 | 12:36 AM
Tdubbs's Avatar
If it was me, I would personally replace all of it while I was there. New everything would most likely last you the longest/be the most reliable. Just my .02
Old 08-11-2016 | 02:13 AM
Sl0wbaltSS's Avatar
NEVER resurface the LNF/LSJ flywheel. You WILL be taking it back apart in a few months. Always get a new Flywheel along with Flywheel bolts.....
Get the GMPP LSJ clutch unless you're big turbo then get something better..
But avoid the KYS3, it's a trans killer and the engagement sucks.
Old 08-11-2016 | 05:53 AM
63 Nova SS's Avatar
What clutch are you running tom? You will be making more power so it's probably not a bad idea. Unless you are building/installing a better trans in the next couple of years. How many mile are on it?
Old 08-11-2016 | 08:40 AM
tomj77's Avatar
I'm running southbend stage 4+ at the moment and will me making a lot of power. I don't wanna spend 700 usd on a new clutch if I don't have to. I love the south bend. It's really not that old but I like new things with new motor lol. Just wanna know if changing The disk alone will work for me or not
Old 08-11-2016 | 09:40 AM
Re-read his post jackass.
Old 08-11-2016 | 09:41 AM
I'd contact Southbend about it, they would be able to tell you the spec for surfacing if it is a good idea or at least they would say no need to resurface the pressure plate
Old 08-11-2016 | 01:34 PM
Sl0wbaltSS's Avatar
Re read my ****** post dick.
Old 08-11-2016 | 01:39 PM
Nothing you said really helped him out
Old 08-11-2016 | 01:46 PM
mrbelvedere's Avatar
You can resurface the flywheel
exninja (08-11-2016)
Old 08-11-2016 | 02:05 PM
It literally had nothing to do with the OPs question. Jackass.
Old 08-11-2016 | 03:48 PM
tomj77's Avatar
Ok I don't care about the flywheel, I'm asking about the pressure plate surface guys. As u have been told
Old 08-11-2016 | 04:04 PM
63 Nova SS's Avatar
I would do what Eric said and give south bend a call as they are the pros. You have a good clutch with lower miles so I would probably lean more to leaving it in.
You can always replace it when you replace the trans from running the 7163....😬
Old 08-11-2016 | 05:14 PM
tomj77's Avatar
The trans is replaced and I'm running the s257 not the zfr
Old 08-11-2016 | 06:36 PM
63 Nova SS's Avatar
Sorry tom with everyone paying homage to kmo's 7163 build I forgot.
Old 08-11-2016 | 09:36 PM
tomj77's Avatar
lol kmo's build will be sick, as his car is sick as it is already.
The following 2 users liked this post by tomj77:
63 Nova SS (08-11-2016), KMO43 (08-12-2016)
Old 08-12-2016 | 12:44 AM
Omiotek's Avatar
Only an experienced machinest can not blow the tolerence and for the price of an oem one i wouldnt bother. They are cheap.
Old 08-12-2016 | 12:48 AM
Omiotek's Avatar
Just keep your mouth shut. Im getting tired of seeing your non sense and filthy mouth. Your a punk and nothing more. The fact that im wasting my time posting this is beyond me but meh..... Its people like you that make me not want to post here anymore. You should be delt with accordingly.
Post something useful for once and keep your swearing and bs commentary off the forum
The following 4 users liked this post by Omiotek:
63 Nova SS (08-12-2016), cluelessk (08-12-2016), ECaulk (08-12-2016), user 72239 (08-12-2016)
Old 08-12-2016 | 07:05 AM
tomj77's Avatar
I agree he should be nicer, but he is right, I didn't ask about the flywheel because I said I was getting a new one. I asked about the pressure plate surface , so the posts about the flywheel help me nothing. If people would read posts right they would not answer with information I already know and don't need. That was his point.
Old 08-12-2016 | 07:06 AM
tomj77's Avatar
So I looked at the pressure plate surface and it is very little wear. Almost new. So I'm gonna just leave it and probably get a new disk and flywheel
Old 08-12-2016 | 09:41 AM
tomj77's Avatar
Talked to southbend , the recommend everything he was the user pressure plate and friction plate will have issues wearing properly when friction plate is new. So I'll just keep my clutch how it is, if I remember what side goes where, or I'll just get a New clutch period
Old 08-12-2016 | 11:44 AM
user 72239's Avatar
did you even read the post? He said pressure plate. god you're an idiot
Tom, I'd just get new stuff. resurfacing a pressure plate is a bad idea. You have it apart...dont do what I did and not spend the money only to have to take it out and do it 6 months later. trust me on this
Old 08-12-2016 | 01:22 PM
tomj77's Avatar
Ya I'm gonna do that. I guess I'll sell my lightly used clutch for like half the price of anyone wants a cheap southbend stage 4+ should last a while yet
Old 08-12-2016 | 03:15 PM
Sl0wbaltSS's Avatar
Damn you guys are retarded smh.
Old 08-12-2016 | 03:20 PM
Says the one that can't read
Your info is correct I'll give you that but nothing to do with what tom asked, that's the problem
Quick Reply: replacing clutch disk
