Selectable tune: Cruise control or Traction control
Old 07-17-2009 | 03:11 PM
  #51
VinceTrifecta's Avatar
Originally Posted by madlion
if you use your cruise control button does it lose function its function to use cruise control or does it still work some how. id miss me booze control
You wouldn't loose booze control if you wanted to use your cruise control switch.
Here's how it would work:
If you have the "master enable" for cruise control ON it would select one tune, and if you have the "master enable" for cruise control OFF it would select a different tune. But, the cruise control would work normally if the "master enable" is ON
Old 07-17-2009 | 03:17 PM
  #52
umrdyldo's Avatar
Originally Posted by VinceTrifecta
I have a tweak for that too - no more spare ECMs will be needed. Regardless of what's in the ECM it will always report itself as an authentic GM flash.
You pull that off and prove it. I'll purchase it no questions asked.
I loved the tune for my LS. Can't imagine the power in this beast.
There is enough free EEPROM space to add multiple desired torque, commanded AFR and timing tables (and the code to switch between them).
I think too many people see the ECU as a set list of things to change instead of a computer that the entire code can be changed.
Old 07-17-2009 | 03:20 PM
  #53
That's right. This thing is a computer (that uses a CPU not unlike the XBOX 360). It has an operating system. The possibilities are absolutely endless.
Old 07-17-2009 | 03:21 PM
  #54
elecblue06's Avatar
schweet so the switchable tune comes with our favorite liquor
  #55
ClearImageAuto Dan's Avatar
Well, looks like Vince decided to let the cat out of the bag.
Amazing job Vince, as always.
And this, my fellow forum members, is the difference between someone who uses software and someone who writes software. Not to mention Vince developed the computer language to communicate with the PCM.
Now for my input on the MULTIPLE tune options.
Vince, when cruise control is ON, why not leave the stock tune, or a tune specifically written to enhance fuel economy. Hence, Cruise control equals econo mode.
When the cruise control is switched "off", the GM Stage tune equivalent is turned on, performance mode.
Then, when competition mode is selected, the extreme tune is turned on, beast mode.
This allows the owner the best of everything.
Old 07-17-2009 | 03:23 PM
  #56
Terminator2's Avatar
I guess that pertains to the stock OS not a custom one.
Old 07-17-2009 | 03:24 PM
  #57
steddy2112's Avatar
Because traction control on with 23 psi is retarded and bad...30 pounds would be the death of clutches.
All of em.
Hypersingle
3+
Old 07-17-2009 | 03:29 PM
  #58
MaxVQ35DE's Avatar
Um yea Vince you are THE MAN, youve got my buisiness, This superchips programmer is up on craigslist when your ready to sell the 09 stuff
Old 07-17-2009 | 03:35 PM
  #59
sponge14's Avatar
Will that be something that we who are already tuned can take advantage of? Maybe at the time I do my reflash for my new Intake (whenever they may fix that, but I know you know best about that since CIA is working with you) and my downpipe that is already installed?
Edit: Sorry, I just read page 2....
Vince, can you tell me, IF the CIA sri intake is fixed and shown to NOT lose power, can I get a retune for that intake (since aparantly I will need it based on the MAF issues as I understand them, which is barely) and my downpipe? Would I see a benefit with a retune for my parts? I don't think I would want to chance the 30lb beast when you release it, unless you can somehow prove it to be reliable and safe?!?!
Old 07-17-2009 | 03:39 PM
  #60
elecblue06's Avatar
i would assume so it shouldn't be too difficult
Old 07-17-2009 | 03:44 PM
  #61
DoMiStIc_RuSh_06's Avatar
Im also going to order this when you release it....I dont want the 30psi tune tho......maybe 25psi....lol
Old 07-17-2009 | 03:45 PM
  #62
umrdyldo's Avatar
Same here, I want a tune that is reliable and not going to blow my clutch apart.
Plus GM not being able to see a tune change is what we all need.
Old 07-17-2009 | 03:51 PM
  #63
madlion's Avatar
DAN I WAS THINKING THE SAME THING about the cruise control.. enable = economode off=***** 2 the walls mode. also i knew that the cat was out of the bag when that clutch thread was posted a week or two ago lol. trifecta and clear image you guys provide great support for the balts at a price to match. thanks and keep it up
Old 07-17-2009 | 03:58 PM
  #64
hallss's Avatar
i say cruise control
Old 07-17-2009 | 03:59 PM
  #65
Stamina's Avatar
So the tune is independent of the cruise resume/set buttons and only on the master enable... I like it. You've won me over. That's cool that you get to keep full independent control of your traction and stability controls as well as cruise control that way too.
I'm guessing you're calling the "Master Enable" the left steering wheel thumb button; The mute/bluetooth equivalent button, but on the left side?
I really like the fact that you can set the econo-mode without having to enable the cruise control too.
Old 07-17-2009 | 04:03 PM
  #66
MaxVQ35DE's Avatar
Vince ive already got a second ECU with Superchips on it, If i flash to stock could we still use that one rather than the original E69 computer
Old 07-17-2009 | 04:04 PM
  #67
Yes - my HHR has an amber LED in that button
Yes...
Last edited by VinceTrifecta; 07-17-2009 at 04:04 PM. Reason: Automerged Doublepost
  #68
peachpuff's Avatar
I think using the cruise control buttons is best, some people still want the additional power and still have traction/stability on, partially off or completely off.
Old 07-17-2009 | 04:05 PM
  #69
CudaJoe's Avatar
If it is set to cruise control off, this means I'll have to set my crusie control to on in order to avoid destroying my clutch? That sounds like a daily pain in the butt. Or can you just drive conservatively in tuned mode and not hurt anything.
I like Dans Idea! Doesnt competitive mode just turn on the launch control and remove traction control while still keeping Electronic Stability control? If the tune is there, will the ESC still be there as well?
Old 07-17-2009 | 04:06 PM
  #70
Stamina's Avatar
The time has finally come for me to use this:
Old 07-17-2009 | 04:08 PM
  #71
CudaJoe's Avatar
I dont need to say it....
Old 07-17-2009 | 04:09 PM
  #72
Yes, ESC will still be there.
Old 07-17-2009 | 04:10 PM
  #73
Stamina's Avatar
This is what I get from this:
Dont do anything: "Normal" Trifecta tuned mode
Push the left steering wheel cruise control button (the one with the light in it): Econo-mode on
Switch to Competitive Mode: Beast mode
I see a possible conflict here though. What happens if somebody accidentally leaves the amber light on and switches to competitive mode?.. which one takes priority? Sounds like a programming thing that needs to be tackled.
  #74
I think we will allow the customer to choose what they want in the order form - it seems like different people want different things - why not let everybody have what they want?
Old 07-17-2009 | 04:11 PM
  #75
CudaJoe's Avatar
yea good point. what if cruise control is on and comp mode is also on?
