SS/TC vaccum hose diagram?? Help
Old 04-10-2016 | 07:27 PM
cooljake73's Avatar
I have a 09 SS/TC and trying to find a diagram online of the vaccum lines on the engine and what each is called because I got a few to replace. Anyone know where to find a diagram and where's the best place to buy the hoses? Or is there a site that sells the hoses and shows where each is located on the engine?? Been looking for hours and can't find what I need! Any help would be appreciated!
Old 04-10-2016 | 08:14 PM
tomj77's Avatar
Lol cut a small pc off one of the hoses, goto a hardware store and ull find all u need there.
Old 04-10-2016 | 08:15 PM
tomj77's Avatar
Just buy like 10 feet or so and pull the ones off the car and cut them to length and there u go
Old 04-10-2016 | 08:18 PM
cooljake73's Avatar
I thought about that. I didn't know if that was ok to do Or not.
Old 04-10-2016 | 08:19 PM
cooljake73's Avatar
You use the factory pinch clamps or has anyone switched them all out with worm gear clamps instead? Just asking because I work on a assembly line for John Deere and I see where the pinch clamps don't hold up so we replace them with the worm gear clamps
Old 04-10-2016 | 08:56 PM
If you can find worm gear clamps that fit then go for it. The pinch clamp works well for smaller lines not so good for larger lines.
Old 04-10-2016 | 09:48 PM
cooljake73's Avatar
I got a bunch of different sizes. Just having trouble finding the hose that's on the front of the engine manifold on the right hand bottom side a bigger hose maybe 3/4-1" in diameter. Runs out and bends back by oil filter and goes back. Any idea what that hose is called? Cannot find where to buy that hose or what it's called? Others I can get from a hardware store.
Old 04-11-2016 | 02:15 PM
tomj77's Avatar
That's the brake booster line. Goes to brake booster . I don't even use clamps on some of my hoses I just use a zip tie, works just as well if not better
Old 04-11-2016 | 09:59 PM
cooljake73's Avatar
I hate the pinch clamps. Absolutely junk.
SSxTc0825
11-14-2020 03:05 PM
jdbaugh1
Autocross and Road Racing
06-10-2016 04:40 PM
09TcSedan
04-11-2016 03:23 PM
Gearblock
04-04-2016 09:37 PM
bigdogstokes16
03-29-2016 02:52 PM
Quick Reply: SS/TC vaccum hose diagram?? Help
