Stock lnf cabilities? fuel system, block, tranny, etc.
Old 10-28-2013 | 05:20 PM
Waka Flocka Fluff's Avatar
Originally Posted by raver0789
No. Get the trans. Yes. Run your stock Gen 2 lnf till it blows and replace with Gen 3 LDK. You don't need pistons for 450whp. Save your money.
Convinced on the tranny swap prior to a turbo swap. Just need to save up some cash. I'd rather do it right the first time so. Clutch & tranny swap, stock cams with upgraded fuel lobes, titanium valve springs, and a s256et kit. Shame I already have the down pipe and cold air intake tho :/ I'd just rather not push the zfr to its limits to make 450whp.
Old 10-31-2013 | 04:06 PM
Whats a good 5 speed they offer for this car that'll hold the 400whp I plan on making
Old 10-31-2013 | 04:18 PM
InfraRedline's Avatar
FMSR is really the only ones doing much with the 5-speed right now. ZZP used to, but they don't offer the 4.45 5-speeds anymore. Powell will do it if you can source some 4.45 gears, but he is out right now and it doesn't look like there is much supply left. You can run an LSJ trans with slightly shorter 4.05 gears. It will help, but won't hold a whole lot more than the LNF 3.82 gearing.
Old 10-31-2013 | 04:24 PM
Zzp still sells the 4.45 trans but is there anything better priced wise? And Powell makes the 4.45s?
[QUOTE="InfraRedline;7189573"]FMSR is really the only ones doing much with the 5-speed right now. ZZP used to, but they don't offer the 4.45 5-speeds anymore. Powell will do it if you can source some 4.45 gears, but he is out right now and it doesn't look like t
Last edited by Waka Flocka Fluff; 10-31-2013 at 04:24 PM. Reason: Automerged Doublepost
Old 10-31-2013 | 04:32 PM
Fmsr wants 2500$ plus my tranny for the stage 2 swap f35 tranny. That's crazy!
Old 10-31-2013 | 04:39 PM
raver0789's Avatar
I told you to contact Powell already lol
Old 10-31-2013 | 04:44 PM
Is that his name on cobaltss.net? And the fmsr offers payment plans which would be nice.
Old 10-31-2013 | 04:59 PM
Area47's Avatar
Rent me! per hour
Originally Posted by fl0wVdub
I wouldn't really blame third gear or the tranny, yes they are weak, but it's also how u drive the car. I have over 100k on my tranny, but I also only go wot @4k or above. A lot of it is ur tune and ramped in boost. Just my two cents
he is alive!
Old 10-31-2013 | 05:02 PM
ZZP sells the F40 6-speed. I talked to Tim last week and he said they no longer offer the 4.45 5-speed services. Powell can do it if you have gears, but all his current 4.45 gears are spoken for. FMSR has some 4.45's left. Trans work isn't cheap.
Old 10-31-2013 | 05:04 PM
raver0789's Avatar
John@powellraceshop.com
Last time when we had a coffee together he said he was pulling some from a secret source. Email him.
Old 10-31-2013 | 06:43 PM
  #36
John@powellraceshop.com Last time when we had a coffee together he said he was pulling some from a secret source. Email him.
Email sent, also figured out the knock setting haha thanks for that help man
Old 10-31-2013 | 10:46 PM
  #37
How's the f40 conversion? How much power are they good for stock?
Old 11-01-2013 | 10:00 AM
  #38
r3v07ut10n's Avatar
Raver i heard this as well, i know john has my gears waiting for spring time. Better to change out know before i do break 3rd and cost me a 1k i didnt need to spend. Being retroactive is 1 of the most important things when upgrading performance items in your car imo.
Old 11-01-2013 | 10:49 AM
  #39
Bump for info on the f40 conversion!
Old 11-01-2013 | 11:37 AM
  #40
Go read some of zzp's threads on it and the discussion in some of the recent FMSR threads on it. ZZP has track tested it and written reviews on here. Hate to be the guy that says "search", but there is some really good info in those threads!
Old 11-01-2013 | 01:01 PM
  #41
I'm not worried about hearing and all that fancy jazz I just wanted to know if it can handle the power because it's actually the cheapest swap available. Mainly because it comes with everything. I looked it up and it'll work on my build.
Old 11-01-2013 | 01:29 PM
  #42
The F40 is more expensive than the 4.45 F35's typically, but yes it does come with everything you need for about $3,700 shipped. That is the route I am looking at taking. They say they seem to be good to 700whp or more, as I don't believe they have broken one yet.
Old 11-01-2013 | 01:51 PM
  #43
The main reason I want the 6 speed is because I can daily drive it swap the tranny and keep driving. I don't have to worry about sending out my old tranny. Plus I can sell my old tranny clutch flywheel and short throw shifter and make at least 1,000$ back.
Turbo Johnny
02-21-2019 10:41 AM
hhrfreek
06-05-2016 12:25 AM
camaromanss1992
10-01-2015 11:51 PM
Cptnslo
09-24-2015 10:32 AM
Josh@ottp
09-08-2015 11:18 AM
