Wastegate and PCV Lines
Old 08-30-2016 | 07:09 PM
sstcsfsd's Avatar
I'm looking for some assistance.
Is this how the fittings need to be for using the stock boost controller? or do I need to move them?
And also I'm not sure on the Pcv Lines. I've read the one on the passenger side can be left open, and the one out of the middle goes into the air intake? is this correct? Do I need anything else?
Thanks
Old 08-30-2016 | 09:03 PM
tomj77's Avatar
Um, u only need one fitting if ur using the k04 solenoid, if I'm understanding u right. Use whatever air port u wish and the line on the side of the stock solenoid would plug into the air port on the waste gate. The front port on solenoid goes to turbo, the back port is left open or goes back to intake if u have a place for it which I doubt u do.
Old 08-30-2016 | 09:23 PM
sstcsfsd's Avatar
I just didn't want to leave the top bare threads, so I put the fitting in. I just wanted to make sure it was the top port needed to be open and not the top side port. So assuming top port gets left as is, this is correct for stock boost solenoid?
Old 08-30-2016 | 09:34 PM
tomj77's Avatar
no, take one of the air fitting out and plug it with one of the plugs that should have come with the wastegate.
Old 08-30-2016 | 09:40 PM
sstcsfsd's Avatar
Plug both top ports? They only come with 3 plugs, I plugged the 2 unused bottom ports, and the top side port.
Old 08-30-2016 | 09:43 PM
tomj77's Avatar
ok I got it wrong. u plug 2 side air ports, and use the open one for boost reference. u plug the top side port and leave the very top one as it is. so u should only be using one air port on the side and that top one is a vent to atmosphere. watch video
Old 08-30-2016 | 09:52 PM
sstcsfsd's Avatar
Thank you, do you know the best way to run the pcv lines?
Old 08-31-2016 | 12:02 PM
tomj77's Avatar
To a Powell oil separator lol
Aroooo
08-10-2016 09:19 PM
z06ske
07-31-2016 10:55 AM
haachu
07-18-2016 11:28 AM
gmkss/tc
Tuning
07-05-2016 07:34 AM
katriik
06-29-2016 03:04 PM
