Weird power loss problem
So, can't figure out what is wrong with my car. I have this problem with it where I can get in it and drive it no problem, but then I park it and go into a store and come back out and I turn it on and it seems fine. But as soon as I drive it after that warm start up it will be like it lost all its power and the turbo would flutter or surge(idk which one.) so after that I hooked the bpv to the intake manifold and plugged charge pipe thinking it was the bpv system messing up. Turns out it's not that since I got in my car today and it did the same thing and I was disappointed. I did have a previous problem with my map sensor wires grounding out but I got that taken care of/rerouted and it has a casing around it. I clear the engine codes with a scanner and it runs fine again. Has to be something electrical and any insight is much appreciated!
Originally Posted by tomj77
Flutter is that flutter noise when bpv doesn't open when letting off has, surge is when ur on the gas and ur turbo starts to flutter without u letting off the gas
Just curious if your bpv is aftermarket? If so have you clean, and lubricated it? I don't know if the stock one needs a cleaning and lubrication if so maybe there is something stopping or slowing down the bpv's function.
It's the stock bpv
In my first post it says I've done this and I'm currently running it this way.
I'm just wondering if there another sensor besides the map that would cause these symptoms.
Plugin the BPV directly to the intake manifold.
09SS7163
03-10-2016 12:30 AM
tamadrummer
03-08-2016 12:50 PM
