What Does a 625+ WHP LNF Look Like?
Old 06-22-2011, 08:36 PM
  #76
Mike08ss/tc's Avatar
That is def a big booboo. I can just imagine what it will be like when it is back on the streets.
Old 06-22-2011, 08:44 PM
  #77
overboostedss's Avatar
450 500
Old 06-22-2011, 08:47 PM
  #78
cmiller8006's Avatar
Originally Posted by overboostedss
450 500
On what fuel? I know Matt has been in the 5's with the stock fuel system and race gas. I also think he ran 500 or more with just the upgraded cams, I may be wrong on that though.
Old 06-22-2011, 08:54 PM
  #79
E-85, 93s barely available around me
Old 06-22-2011, 09:04 PM
  #80
Sweetsandman's Avatar
Impressive! I'm surprised it made it there! I'm also surprised it was still running after that happened lol!!
  #81
Omnigear's Avatar
didnt black push 600's in stock form on an lsj. dun dun dun
Old 06-22-2011, 09:15 PM
  #82
mongorat427's Avatar
Originally Posted by Matt M
The craziest thing about this is that the engine didn't stall. It just changed pitch quite a bit and sounded rough. I brought it to a stop and then turned it off with the key. Of course there was a decent amount of smoke, but it was still running!
Ha Ha I blew a big block at 8000 rpm and one rod came thru the block and oil pan and stuck 2 inchs into the crossmember. I drove it onto the trailer. The piston was buried in the side of the block
Old 06-22-2011, 09:20 PM
  #83
jboogie's Avatar
That block would make a great table in my man cave!
Old 06-22-2011, 09:47 PM
  #84
80vetteL82's Avatar
haha thats awesome!
BTW.... I need a DP, hook me up! ...but seriously, any chance on any sales or GB's coming up?
Old 06-22-2011, 10:54 PM
  #85
Matt M's Avatar
Originally Posted by IonNinja
How long did the motor last at this power level?
A couple hundred dyno pulls over 400whp. Probably 100 or so above 500whp. About a dozen pulls at 600+.
Old 06-22-2011, 10:57 PM
  #86
Matt M's Avatar
What about the extra fuel rail
I wasn't running the secondary fuel rail. We came up with a much less expensive, much easier to install setup in place of the upper rail port injection
Old 06-23-2011, 12:01 AM
  #87
bogalusahondakiller's Avatar
i want 500 now... wish i would have bought a turbo upgrade instead of bolt ons now
Old 06-23-2011, 01:05 AM
  #88
JustACobalt's Avatar
thats what i like to hear!
Old 06-23-2011, 01:13 AM
  #89
utsadude's Avatar
You didn't hear? They took a 1/4 inch drill bit and drilled all the way through the injector.
Firing is a little random, but big horsepower is worth it.
[ waits for "I screwed up my injectors" thread ]
[/waiting]
Old 06-23-2011, 01:20 AM
  #90
i heard about them experimenting with that but im just glad it wasnt the hpfp that couldnt keep up. @ around 390 whp, i was starting to get worried about fueling limits
Old 06-23-2011, 01:23 AM
  #91
utsadude's Avatar
:facepalm:
Old 06-23-2011, 01:53 AM
  #92
FasterIsBetter's Avatar
Hey....I see your crank......
And have you discovered the power limits for when just upgrading to your rods and wiseco pistons? Are they even capable of being reached in a fwd car?
Old 06-23-2011, 01:58 AM
  #93
40rty's Avatar
Can this system work with the Sky Redline? Will this be available by the end of the year?
Old 06-23-2011, 02:04 AM
  #94
Omnigear's Avatar
Old 06-23-2011, 09:52 AM
  #95
Matt M's Avatar
We have not pushed a setup like that very far yet, unfortunately.
Yes, it should work in the Kappas.
Old 06-23-2011, 10:04 AM
  #96
defo98's Avatar
Originally Posted by Omnigear
haha the mexicans at my work say that all the time!
Old 06-23-2011, 10:54 AM
  #97
FF_ace's Avatar
I wouldnt mind trying out some of your fueling upgrade part im running carrilo rods, weisco pistons running a 5857
Old 06-23-2011, 01:49 PM
  #98
rukkee's Avatar
I don't get why people are so disappointed with the outcome ..... thats close to 700 crank hp on a stock bottom end ..... Maybe 5% of LNF owners will ever need to worry about running power levels like this one did.
The way i see it with all those pulls over 400 and 500whp ....it hasn't had an easy life like someones daily driver with a GM stage kit lol. To me it's pretty damn impressive that it held on as long as it did.
It's kind of amazing that it kept running lol...... did anything make it out the exhaust side to the turbo?
Old 06-23-2011, 02:29 PM
  #99
09CobaltSS1's Avatar
I think most people also weren't really realizing that this was a bone stock LNF bottom end (stock rods, pistons, balance shafts, everything stock) and got caught in comparing it to the built LSJ that ZZP was testing the failure point of their girdle and H-beam rods. Obviously there is a big difference between the 2 bottom ends at that point.
Old 06-23-2011, 02:37 PM
  #100
Fastgti69's Avatar
All I know is, this is a great motor with lots of potential once fueling is done. Built motor is a breeze, tuning will be done according to consumers needs. Turbo kits are out there with more than 500whp capabilities. ******* awesome engine.
Quick Reply: What Does a 625+ WHP LNF Look Like?
