What Does a 625+ WHP LNF Look Like?
Old 06-23-2011, 03:06 PM
  #101
rukkee's Avatar
Originally Posted by 09CobaltSS1
I think most people also weren't really realizing that this was a bone stock LNF bottom end (stock rods, pistons, balance shafts, everything stock) and got caught in comparing it to the built LSJ that ZZP was testing the failure point of their girdle and H-beam rods. Obviously there is a big difference between the 2 bottom ends at that point.
I think your right..... and like you said apple's to oranges for sure.
Old 06-23-2011, 10:06 PM
  #102
skip_jones's Avatar
pop goes the weasel.
Old 06-23-2011, 10:10 PM
  #103
1LowLS's Avatar
A little bit of this in the oil and ****'ll buff out
Old 06-23-2011, 11:10 PM
  #104
FutureEcotecOwner's Avatar
More info on the stage 2 cams???
Old 06-23-2011, 11:39 PM
  #105
Omnigear's Avatar
tussin 4tw. some1 watches every1 hates chris =p
Old 06-23-2011, 11:44 PM
  #106
09BlueBaltSS's Avatar
awesomeness, was hoping the EFR would be the one bolted up but oh well. What exactly gave? Wrist pin?
Old 06-24-2011, 03:12 AM
  #107
1LowLS's Avatar
I've only seen it a couple of times.I got this from Chris Rocks standup .
Old 06-24-2011, 03:32 AM
  #108
Berto09ss's Avatar
ha the bottom end can handle a good amount
Old 06-24-2011, 03:53 AM
  #109
40rty's Avatar
Haha, just trying to reach my goal by the end of this year.
Old 06-24-2011, 10:23 AM
  #110
efactor's Avatar
I believe his Cobalt was starting to go Super Saiyan on him and go, "Kamehameha!"
Old 06-24-2011, 10:41 AM
  #111
09CobaltSS1's Avatar
hmmmm
Old 06-24-2011, 11:10 AM
  #112
CudaJoe's Avatar
I think its more like Spirit Bomb!
by the way, used to think that show was awesome back in the days.... watch a recent episode of the frieza saga and I gotta say.... gayest f*ckin **** on the earth. lol.
Old 06-24-2011, 07:44 PM
  #113
overboostedss's Avatar
OK so what kind of fueling modifications were u running?
Old 06-24-2011, 07:58 PM
  #114
reading fail..
Originally Posted by Matt M
Where is this coming from? There are people running more than 625 whp on stock LSJs?
This bottom end is completely stock. Stock block(no girdle), stock crank, stock rods, stock pistons. It has ZZP S2 cams and ZZP valvesprings. The turbo setup is our normal LNF upgrade kit with a S259 extended tip turbo. The fuel system mods include our modified fuel pump cam lobes and our extra injector kit, as well as an in-tank pump upgrade. It is running on E85 from the local Mobil station.
Old 06-24-2011, 08:07 PM
  #115
^this^
I wasn't running the secondary fuel rail. We came up with a much less expensive, much easier to install setup in place of the upper rail port injection
Old 06-28-2011, 05:40 PM
  #116
Matt M's Avatar
I see that the wording could make that confusing. I said, "I wasn't running the secondary fuel rail" meaning that this setup does not have 4 additional injectors with one in each intake runner. Then i stated that it has our "extra injector kit" meaning that there is one additional injector. This setup does not require removal of the intake and it costs at least $500 less than the port fuel setup.
Old 06-28-2011, 05:42 PM
  #117
Matt M's Avatar
I took this motor apart yesterday. Here are a few more pics-
Notice that rods 1, 3, and 4 don't look bent much if at all. They looked worse on the previous engine that made about 100 less HP. I have a couple theories as to how this could be.
Old 06-28-2011, 05:50 PM
  #118
I heard that u just put a 60# injector into where the evap sensor was and used the lsj boost reference fuel controller to kick it in for the e85. True?
Old 06-28-2011, 06:00 PM
  #119
celblazer's Avatar
Some JB weld should take care of that little crack. LOL
Old 06-28-2011, 06:04 PM
  #120
conerboner's Avatar
damn! can't wait to see what you do next
Old 06-28-2011, 08:28 PM
  #121
Fastgti69's Avatar
nice pics.
Old 06-28-2011, 09:48 PM
  #122
Matt M's Avatar
I've never heard of an "lsj boost reference fuel controller" so I'm going to have to say no.
Old 06-28-2011, 09:56 PM
  #123
The head and crank were the only things holding the block together lol. If your going to fail a motor this is how you do it god dammit!!!!
Old 06-28-2011, 10:03 PM
  #124
damastah's Avatar
DAMNNN!!! arent those forged as well? musta been some serious power
Old 06-28-2011, 10:16 PM
  #125
Gremlin85's Avatar
What are your theories, Matt?
Quick Reply: What Does a 625+ WHP LNF Look Like?
