What to replace on timing chain with play/looseness?
08 lnf
I have been hearing a ticking noise for a few months now(supposively it was normal) doubted it
So i decided to check it out today I removed the valve cover and checked for anything loose and found that the timing chain was loose and as i moved it that was the same noise I have been hearing Idk what to do /replace anyone got any advise links on what to buy to fix my problem??
Pull the inspection plug in the side of the head, by the motor mount. Make sure that bolt isn't broken. If it is, get a repair bolt for that from Mongo.
If it's not broken, order an entire timing kit, replace everything with NEW bolts. I'm seeing them all the time on higher mileage ecotecs, the tensioners get weak and allow the chain to float and it beats the guides into pieces.
New timing kit and tensioner, CED has good prices on them.
Rock auto stuff is fine as long as you choose something name brand. The cheapo aftermarket tensioners I wouldn't trust too much, but the chain and stuff, in a stock car, is whatever. If you're in an LSJ or LNF and you wanna abuse the car, then go back OEM. I had a good quality aftermarket chain come apart in a built QR25 I did for a friend and it almost cost us the engine. Not worth it in a highly abusive situation.
