Wheel Hop, Ingalls Torque Damper, and K&N SRI
So our LNF Cobalt has tremendous wheel hop at the track (and on the street) if we do anything over about a quarter throttle all the way through first and second. I can actually get it to wheel hop (maybe more of a wheel jiggle) at 40mph in second.
We have a K&N intake, mostly for the panda sneeze since we haven't tuned yet (and in slow poor people preparation for an eventual tune) and, from what I understand, the K&N intake and the Ingalls Torque Damper, which seems to be the best, cheapest, most effective possible solution to our problem, is incompatible due to the heat shield on the K&N.
Has anyone tried simply removing the heat shield? Does that make the Stiffy (lol) fit? It seems counter-intuitive to care too much about the temperature of the air going in to the engine when we can't even get traction through second gear.
take that Ingalls off and throw it in the trash. No, seriously. Trash it.
Buy Powell rotated mounts.
Ill give you my paypal and you can send me beer money as a thank you.
Edit: Also, how much do those cost? They seem to be the way to go for mounts but I don't see any prices listed anywhere for them.
I'm using zzp's front tran's mount and I love it. Much less engine movement and wheelhop reduction and very little cabin noise. I actually like the tiny vibrations inside the car. Feels like a race car.
Do what 07 said. Powell mounts are the way to go and they vibrate much less than the non rotated ZZP mounts. Pretty much feel like stock inside the car.
If you have the money I would also invest in powells rear cab bushings. You should be good after that. I'm also in for the beer money.
07MetallicSC (11-23-2015)
My IRL is actually smoother than my GF's bone stock 2011 chevy aveo with half the mileage lol.
Completely agreed, the Powell mounts vibrate just slightly more than stock, but nowhere near what the other aftermarket companies mounts do (which use polyurethane instead of stiffer than stock rubber). My IRL is actually smoother than my GF's bone stock 2011 chevy aveo with half the mileage lol.
Op, you get used to the vibrations and you will learn to like it. If you plan on getting a tune, it is pretty much a must have part if you wanna save your axles. As the above member said, worn cabs can also cause will hop and upgraded spherical bushings are relatively cheap and easy to replace (as long as the bushing isnt seized to the cradle bolt).
Your lower control arms have 2 bushings. The one under the strut is the t cab and the one closest to the driver is the rear. On higher hp cars the rear ones tear and cause the control arm to move under power instead of being a solid type mount. This can effect wheel hop. The t cab can effect your turning on say a road course because they introduce slop. They can also effect wheel hop but generally they don't wear out as fast as the rear ones. The Powell mounts use a very hard rubber and a beefy shell that really stiffens up the arm.
CobaltBlack (11-24-2015)
These are the TCABs I installed in my SS/TC. Fit perfectly.
I'll also PM Powell and see if he is still selling stuff.
These are the TCABs I installed in my SS/TC. Fit perfectly. Amazon.com: ACDelco 45G9211 Professional Front Lower Rear Suspension Control Arm Bushing: Automotive
Also, are those press-in or do they just slip out? I haven't looked behind the wheel of the car much.
Edit: Nevermind, I looked at a video and there's no way, with my back and hands, that I could do that job in the apartment parking lot. I'd have to pay someone. I might be able to check it, though, but it looks like at least the wheel I'm checking would have to be in the air to be able to tell if that bushing is busted, am I correct?
Heh, it was a joke. If you look at the pic on Amazon, there is clearly some dirt smashed into the bushing. But thanks for the info on the install.
Yeah I saw, no idea why they picked a dirty picture instead of a nice one. They're stiffer than stock as the stock ones were voided rubber
Rear CABS, traction bars, zzp trans mounts, and low enough tire pressure works for me. I launch between 3k-3.5k on the two step around 4lbs boost. Good enough for 2.0 60ft on bad DRs. I really need to bite the bullet and get 15" slicks Front CABS will give similar effect as traction bars but I prefer the adjustability.
