ZFR 7136 Requirements/build
Old 04-08-2016 | 09:15 PM
tomj77's Avatar
Why an lsj tob? And if ur doing all that why not get no o2 angled bung and just delete rear o2 and delete codes?
Old 04-08-2016 | 11:51 PM
blueLNFftw's Avatar
That was the first turbo car I ever drove. It was a beast haha. That car saw no easy life that's for sure and took every minute of it.
I almost bought it.
Problem was it was November when I bought my LNF. I didn't want to drive it back to Florida in the snow and buying one of these cars sight unseen is not something I would ever do for more than $1500 lol.
Old 04-08-2016 | 11:53 PM
blueLNFftw's Avatar
Install opels.
Install fueling cam.
Install hard pipes/IC Kit
Install 3 bar map.
Install ZFR.
Tune 30psi. Dyno. Turn it up.
Build a motor on the side and swap it when the stock one blows. You will be amazed at what these motors can take.
Old 04-09-2016 | 01:15 AM
Jesse09SS's Avatar
Originally Posted by KMO43
Why are you doing all this work? And you don't need head bolts and head studs
Bolts n studs just for when I redo the heads.
And not all at once, just over course of time, in the end I want the ZFR 7163 but just want all the necessary "piece of mind" parts before I get it. I guess you can say somewhat close to final build goals but just was looking for a general consensus on what's Reccomended before I go bigger than stock turbo
Old 04-09-2016 | 03:56 AM
KMO43's Avatar
Originally Posted by blueLNFftw
Install opels.
Install 3 bar map.
Install ZFR.
Are there more guys dumb enough to turn it up to 30psi on a stock block like me???
E25 fully bolted stock engine I made 481 and its still going a year later after making 511
Old 04-09-2016 | 02:06 PM
tomj77's Avatar
I'm almost dumb enough. 2 psi short
Old 04-09-2016 | 06:10 PM
KMO43's Avatar
I ran 29-30psi all of last year and with my ported head and stg2 cams 30 is full retard on stock engine with the 71 and E. I'd run 28 on ur setup all day
Old 04-09-2016 | 07:33 PM
tomj77's Avatar
I'm pretty sure u could run 40 if u had the mods to keep it safe and knock free . Like a butt load of meth and e
Old 04-09-2016 | 07:55 PM
KMO43's Avatar
On stock bottom end you'd have 4 new windows in the block. A 71 won't hold 40 on a 2L
Old 04-10-2016 | 08:18 PM
tomj77's Avatar
Time for a bigger one lol
Old 04-10-2016 | 08:26 PM
  #36
KMO43's Avatar
For who??
Coballin13
06-14-2016 05:11 PM
Snail_SS
02-15-2016 09:31 AM
Brandon Clement
02-10-2016 05:50 PM
SH4DOW
02-09-2016 05:24 AM
