ZZP Clutch rod install...Help please!
#77
k, so now if I put the line back on the master cylinder and tape up the end that is suppose to go to the transmission it build pressure and fluid comes through.
When I put the line back on the transmission and pump starts to sound like air going through again and see no fluid leaking.
So.... H E L P ! ! !
Please.
Please.
#81
the distribution block is good, the seals are good as well. Fluids out the bottom hate to say it, thats the throw out bearing. or the pipe that threads into to the bearing. u b screwed x 2 sorry. I have new tob and clutch pope here if I overnight to you tomorrow its 5 hours re and re to put it in So sorry I see it way too much happening to peeps, it has never happened to me as I ALWAYS put in new each time no matter how painful it gets...(never say never new parts could be wrong) I will pm my cell toyou if you need to text me tomorrow
#82
nutty21.......i hate this for you especially given the specific situation. i hope you can get everything taken care of
powell.........you have done everythig you can short of driving to this guy and you are the only site member who has tried to help him. i just want to say that speaks volumes for you as a person and a business/vendor. a+++++ man
........and you are going to send him a new tow hook. i can not wait to do business with you.
#83
Good to know that's what you think it is. Your most likely right then.
I finally got one of them on the phone and he guessed the slave cylinder, but again, he said he didn't really know and was just a guess. So far they haven't been very good at guessing, even with the car right there in front of them. I've been able to figure out more with the car then they did, and this is all my first time...
Good news is I have the original throw out bearing so as long as they don't screw that one up as well....
Not liking this place. Recommending everyone run from Ford Tusket.... If you ever find yourself in southern NS never go there.
#84
Thanks again.
P.S. for everyone John actually referred me to over the top once via PM to buy a part that he was low on stock on, and knew OTT had a sale on the part at the time also. Mean while I had a thread for recommendations on the part.
OTT came in and bashed Powell Racing's... Was going to mention it then, but that stuck with me. Then the one decision I did make after that was that I wasn't going to buy from OTT. Took them right out of the running.
#86
THey most likely screwed up installing it some how.
Not sure how, or what damage they most likely done.
Would be nice to know before I have to talk to them in the morning.
They dont' know what they are doing so would be nice to point them in the right direction anyway.
#87
ok, so while I have this apart...
I now have the master cylinder here in my hand with the master cylinder rod still in it.
Mine also didn't pop out from the master cylinder when I pulled the clutch.
How can I get this rod out of the master cylinder?
I tried putting it in a bench vice and pulling up on it, but I almost pulled the bench right apart...
There has to be some trick to this.
I don't want to pry it out and damage the plastic master cylinder .
#88
HA HA, got it.
Bench vice + crowbar = cake
Put the master cylinder rod down into the bench vice just leaving a little room between the master cylinder and the top of the bench vice. Stuck the crowbar forked (not sure what else to call that side. Looks like the side of the hammer you pull nails up with) under the master cylinder and pushed down on the crowbar prying the master cylinder upward and POP! off came the master cylinder from the master cylinder rod. Cake.
#89
HA HA, got it.
put the master cylinder rod down into the bench vice just leaving a little room between the master cylinder and the top of the bench vice. Stuck the crowbar forked (not sure what else to call that side. Looks like the side of the hammer you pull nails up with) under the master cylinder and pushed down on the crowbar forcing the master cylinder up and POP! off came the master cylinder from the master cylinder rod. Cake.
#90
#91
HA HA, got it.
Like John said earlier in the thread, the rod isn't really needed if the clutch is bled properly. Make sure you start out as short as it will go so you don't overextend the master or pop it through the firewall.
I took the rod out of mine after replacing the master & bleeding the clutch. I didn't need it with a SPEC Stage 2+ & LW flywheel.
#92
So took the car to the mechanic an they broke the plastic on the master cylinder that holds it in the firewall.
Then they said that the ZZP master cylinder rod was too short, and they wouldn't put it in the new master cylinder they got.
Then after they got that pumping and could see as I told them that the fluid is coming right out the bottom of the transmission they think it is the throw out bearing which they said is the same thing as the slave cylinder. They think that the issue is ZZP's throw out bearing, and not something they did, and want to put the old one back in, and said they may even have to put the old clutch back in.
ZZP if you are here I could really use your help here. I paid 0ver $900 to get this all installed, then they screwed that up, had to pay for a tow truck, then have a feeling they are going to charge me for a new master cylinder and over $1000 for the work today and they are going to try to blame it all on ZZP after market parts not working with this model car...
#93
#94
the zzp tob is an LNF tob afaik. You have no choice but to put the old tob back in as your new one is apparently screwed, and if the clutch was not bad that you took out, on an LNF (if it was my car) I would go totally OEM Bone stock tob clutch flywheel etc, unless u are drag racing. ZZP know drag racing better than anyone with Cobalts, they would no knowingly t ship you defective parts. It is possible ( I said in an earlier pos)t, that a TOB can be defective, it just has never happened to me.
#95
#98
Our TOB is a GM LNF unit as John said. It is possible that it was defective, but more likely that something was done to cause it to fail. Either way, it still needs to be replaced. Sorry I didn't respond sooner, but this is an old thread. I wouldn't think it was a request for customer service. That's why we answer emails every day.
