ZZP girdled block
ZZP girdled block
Hi all,
Since I'm getting the entire forged block from ZZP, I was wondering if the Darton sleeves can be installed in the girdled block
Thank you
Thank you
ZZP wasn't giving me an answer because they don't want to install those sleeves in their forged girdled block. But they didn't tell me if it is possible or not
Do you think whyyoumadson would know? The girdled block is made by ZZP. Unless he bought one, I don't know if he can tell me if it is possible. But I may PM him just to see what he says
Look at their explanation on their site for making a girdled block. It clearly shows that the block becomes weakened when resleeved and the girdled block is reinforcing all the weakpoints of the stock sleeves so theres no point in resleeving the block.
They say that resleeving the block weakens it, but I don't know if then, with the girdle, will still be strong to support all the power. A block with sleeves and girdle may be stronger than just sleeved or girdled.
They say the bottom of the sleeve is "strong enough" and the top is weak, that's what the girdle is for. I'm wondering, is it possible to make the bottom half strong with the Dartons and top half strong with the girdle?
Yes but how ofter they use that car? Only for a few seconds pull or they drive it for 2-3 hours a day?
If that's really the case, sorry Darton. I'm getting the fully built block by zzp with both balancers along with their head/cam combo. That means if it's either girdle or sleeves..... sorry Darton
I'm asking because since I'm getting the entire block built new, I wanted to get all the parts possible at once. But if it is one or the other, I'm getting the girdle and drop the sleeves
they were cramming so much boost into the motor that you will never do and it took it apparently...i mean you don't just make 900 on the first pull, needs to be tuned multiple pulls on boost that again your car won't see.
ahh thought it was the gasket lol my bad
just do what ZZP tells you to do. They know what they are doing. If i could go back I never would have paid for the Darton sleeve kit which cost me close to $2k to get installed. All the advice ZZP has given me so far was 110% correct. If I had listened to them a year ago and gave them my car then I would have had a complete car built to perfection and wouldn’t be still waiting for my car to be complete. I would have also saved a ton of money. Don’t waste your money on getting it sleeved. You won’t ever put down as much as ZZP has and they know the car inside and out. If they don’t want you to install them then it is for good reason.
Ok guys, thank you. I'm doing the full ZZP build. If there is no chance for Dartons, then it was a pleasure to know they make sleeves for the LNF, but.......... no chance then
just do what ZZP tells you to do. They know what they are doing. If i could go back Id never would have paid for the Darton sleeve kit which cost me close to $2k to get installed. All the advice ZZP has given me so far was 110% correct. If I had listened to them a year ago and gave them my car then I would have had a complete car built to perfection and wouldn’t be still waiting for my car to be complete. Don’t waste your money on getting it sleeved. You won’t ever put down as much as ZZP has and they know the car inside and out. If they don’t want you to install them then it is for good reason.
Thank you
I think you're doing the right thing by doing the girdle and leaving the sleeving thing alone though.
They are installed now and the car is all together but is having tuning issues or who knows what. It took the machine shop 6 months to sleeve my block for who knows what reason. I can already tell you what I think of them now that I know about ZZP’s girdle block... The Darton Sleeve kit was a mistake as I lost a ton of money and could have had my car built a lot better and stronger for much less money if I were to have just bought ZZP’s Girdled Block. So save your money and buy the best (ZZP’s) and don’t waste your money with the sleeve kit. If this option from ZZP was available a year ago I would have been all over it.
Oh, as far as my full build (complete forged block and head/cam combo) I've already spoken to ZZP about it. They made my mind clear and I know what to do. Just I was wondering if the sleeves and the girdle can go together. For the rest, I got it all clear
