ZZP girdled block
They are installed now and the car is all together but is having tuning issues or who knows what. It took the machine shop 6 months to sleeve my block for who knows what reason. I can already tell you what I think of them now that I know about ZZP’s girdle block... The Darton Sleeve kit was a mistake as I lost a ton of money and could have had my car built a lot better and stronger for much less money if I were to have just bought ZZP’s Girdled Block. So save your money and buy the best (ZZP’s) and don’t waste your money with the sleeve kit. If this option from ZZP was available a year ago I would have been all over it.
I'm still waiting to get a few more questions answered around extras I'll need to purchase to finish everything up, planned building/shipping times, and if that Stage 1 cam that comes with it has the fuel lobe or not (the cam page makes me lean no, but the block ordering page didn't have an option either way). Haven't gotten a call back from them today. I'll be trying again tomorrow.
Nice, ok.
Nice, ok.
Just those three questions I mentioned.
So I guess the cat's pretty much out of the bag now, so I'll go ahead and give the basic details:
Girdled block
Wiseco pistons
ZZP 4340 rods
Neutral balance shafts
ATI balancer
Stage 1 ported head + springs and retainers
Stage 1 cams (hopefully with the fuel lobe... need to talk with them about that)
I bought it as the overall "Forged Performance Engine"/longblock kit they offer. I'm keeping it 2.0L though. Going to use the K04 for a while, and maybe switch to the EFR if/when it comes out. Basically wanted beefed-up reliability, while being able to rev it out for a larger turbo later.
I'm also going to put a beefier clutch in there while I've got everything out, so I've been gathering together my parts list for that as well.
Girdled block
Wiseco pistons
ZZP 4340 rods
ATI balancer
#36
This will be my build:
- ZZP girdled forged block 2.1
- Wiseco 88mm pistons
- Carrillo H-Beam rods
- ZZP neutral balance shaft
- ATI SFI turbo balancer
- ZZP ported head/stage 1 cam combo w/ ZZP valve springs 82#
- Supertech .5mm oversized inconel valves
- ZZP Stage 2 Transmission (still didn't decide it going with the 4.42 ratio or not)
- Driveshaftshop Level 5 axles
It should be done by the first half on 2013
Hope you guys like it
#37
Girdled block
Wiseco pistons
ZZP 4340 rods
ATI balancer
I bought it as the overall "Forged Performance Engine"/longblock kit they offer. I'm keeping it 2.0L.
Girdled block
Wiseco pistons
ZZP 4340 rods
ATI balancer
#38
#40
Sorry, but we can't install our girdle with darton sleeves in the block. As far as installing new sleeves to add strength towards the bottom of the sleeves, it isn't necessary. The bottom of the sleeves is already supported in the block.
#41
thank you for your reply. Yes looking around I've already decided to drop the sleeves. So, they are no longer my concern.
Did you look at my post above regarding my build? Can you give me your opinion about it? I'm not ordering the parts and have a local tuner do it, I will ship the car to you
BTW, I've got 2 calls from you guys today but I couldn't pick up at work. I hope someone will call me again tomorrow
Thank you.
Christian
#42
But it won't be for another year and a half. My build costs about 10k just in parts
#43
I'll be able to maybe reuse some things off my old engine, but other things are either bad practice to reuse or those kinds of things that you might as well replace while you're there.
#44
Wow, okay. I'm going to try to have mine up and running in a month or so. We'll see how well that works out. I've got a feeling I'm going to forget a part or two and am going to have to wait on it/them, slowing down progress, so I'm working to get the list of need-to-haves together now to hopefully avoid that.
#45
#46
Basically they are well within the realm of capability for what I'm needing. My car's not going to be a drag car or anything. It's been used as a spirited around town car and Road Course car. Even with the EFR, I'm not planning on taking it past the lower 400s probably. I just didn't see any justification for going more expensive on rods that didn't seem to offer any greater advantages for that power range.
#47
That would be a question for ZZP. The 898whp run was done with ZZP rods if I remember right. I figure if they can do that without any damage to them, then running sub-450whp long term shouldn't be an issue. lol
#48
Wow interesting. Ok, I guess I'll ask Matt about it. Thank you
#49
I couldn't answer that for you. That would be a ZZP question. Granted they made 898whp on the ZZP rods, but then there's that question around "yeah, but for how long". Undoubtedly you're paying a premium for the Carrillo name, but as far as engineered differences in the rods, I couldn't tell you, as I've never worked with them.
#50
I hope Matt chimes in again to clarify this for me.
