ZZP girdled block
#76
500 on pump gas is tough. You would need an open exhaust for maximum efficiency. Both your cat and recirc watsegate would be serious restrictions at that power level. Ported head would help, and forged pistons would add a safety margin, but a 500whp pump gas lnf would be pushed pretty hard to get there.
#77
It is with a recirc wastegate and a cat. That means all of the exhaust flow has to go through the cat. With a few psi back pressure pre-cat, the pre-turbo exhaust pressure has to increase quite a bit higher to drive the wheel. This hurts power quite a bit.
#81
Or I suppose you can make a cat with flanges where I can bolt on for emission testing?
Sorry high jacking your thread AyrtonSenna.. Maybe we all can learned something new and explored new ideas through these discussions?
#82
How about 100 octane on an s252et catless wg recirc with the s1 cams and built bottom end? 450 would be easy on 100 with cams right? We have a sunoco station about 45-50 miles out that I could take the truck, a few 55 gal drums, and stock up there. Either that or go to the strip which is about 50 miles out as well and get 110 for $2 more a gallon.
#83
What about an even larger DP and cat combo? Something like a 4" DP and a larger diameter cat if there is such a cat? Would that work you think?
Maybe a 3.5" cat could be built in to the same downpipe.
#84
So the track downpipe with no cat and the wg to air allows for more power due to flow? If so that's good to know was going to choose recir. Wg due to noise but if it limits power ill deal with noise
#87
So everyone wanting to run the 2.1 doesnt want to do it unless they can get the efr why is that? Would it be a bad idea for a 2.1 and zzp's turbo upgrade kit? or if going to upgrade kit just better to run a 2.0 girdled block? What axles are handling that much hp?
Now let me know zzp just trying to figure things out lots of info being thrown around left and right but not as much facts on it. For instants if I wanted to say me 500hp would I be wrong to say I would plan on this build here:
pump gas 93
ZZP Girdle block reg. 2.0
ZZP Rods
Weisco Pistons
Stockhead/Cam
ZZP Springs/retainers
Upgraded clutch unsure which
Stock trans.
ZZP Stage 1Turbo Upgrade kit(includes piping,dp,turbo,etc)
Tune
possible meth
pump gas 93
ZZP Rods
Weisco Pistons
Stockhead/Cam
Stock trans.
Tune
possible meth
#88
pump gas 93
ZZP Rods
Weisco Pistons
Stockhead/Cam
Stock trans.
Tune
possible meth
pump gas 93
ZZP Rods
Weisco Pistons
Stockhead/Cam
Stock trans.
Tune
possible meth
Check out with Matt, but I'm sure he will confirm what I wrote.
I'm getting the same thing as you next year, just I'll get the 2.1 and the head/cam combo
#90
The axles are sold by driveshaftshop
#92
There are a few threads about it. Try to search for it. If not, you can email ZZp and they will contact you by phone.
#93
So, once I get my 2.1 girdled forged block with the head/cam combo, I'm thinking to replace my 55/57 with the 62/62. Does anyone know approx the spooling time of this turbo when combined with the 2.1 girdled forged block by zzp? The 62/62 will be installed on the midlenght manifold that came with the AutoWerks kit
