ZZP LNF Turbo Upgrade- First Dyno Session
Old 11-06-2009, 09:14 AM
  #426
06blackg85ss's Avatar
They won't
Old 11-06-2009, 06:25 PM
  #427
MaxVQ35DE's Avatar
HP tuners is making easier money with the V8 crowds.... Vince and ZZP mean alot more to our LNF modding future.
Old 11-06-2009, 07:27 PM
  #428
marcusicp's Avatar
Originally Posted by 06blackg85ss
They won't
Why not? Not enough of us to make it worth it? Or do you know something we don't?
  #429
mkriebs's Avatar
Pessimism.
Old 11-06-2009, 07:53 PM
  #430
StyleandSpeed's Avatar
Im just curious how well the stock axels will hold up to this much mods on slicks
Old 11-06-2009, 07:59 PM
  #431
FutureEcotecOwner's Avatar
I think the axles are pretty stout, atleast that's what I've heard.
Old 11-06-2009, 08:00 PM
  #432
mkriebs's Avatar
No worries... DSS already has a stage 1. But, shouldn't be a problem. I think the trans is weaker than the axles.
Old 11-06-2009, 10:39 PM
  #433
elecblue06's Avatar
the lnf has been out in the sky solstice for years now.. and we're just seeing "updates"
and i'll tell you why nothing more will happen.. ford... yes... ford.. hptuners is now starting to tune fords
Old 11-07-2009, 04:32 AM
  #434
oopsitouchedmyself's Avatar
^^^ and dodge.
Old 11-09-2009, 09:49 PM
  #435
mezzanno's Avatar
yeah the axles in the lnf car are fine. The tranny's well... not so much.
Old 11-10-2009, 12:32 AM
  #436
Rent me! per hour
Area47's Avatar
if you want to put the dss axles in your rc's. go for it. i'll take your stockers
Old 11-10-2009, 03:03 AM
  #437
mkriebs's Avatar
You can have the two stockers I have laying around here some where. Might do you better to only have 2 parts rather than 3 though.
Old 11-10-2009, 09:25 AM
  #438
Rent me! per hour
Area47's Avatar
sweet
Old 11-23-2009, 12:10 AM
  #439
pt5457balt's Avatar
Anything yet from zzp on what was used to boost fuel rail pressure limits?
Old 11-23-2009, 03:47 AM
  #440
SSlobalt's Avatar
They explained it somewhere in this thread.
Old 11-23-2009, 08:51 AM
  #441
pt5457balt's Avatar
I just read the whole thread (skimmed), didn't see anything about it.
Originally Posted by Matt M
We don't have these parts available yet. We are working on plug n play options and trying to keep the cost down.
Any chance for a one off then at a slightly higher price? If so, pm me some details, i'd love to get this hammered away before getting it all back together.
Bump.
Old 11-23-2009, 10:05 AM
  #442
Deadman's Avatar
nothing as of yet... still very interested in how/what was done.
Old 12-01-2009, 03:57 PM
  #443
turbod ss's Avatar
subd
Old 12-24-2009, 08:20 AM
  #444
Deadman's Avatar
so what does the ecu actually limit? What did you use to tune/ solve throttle closing issues?
My main question is what was needed to get past the 400whp "Wall" or so to say? *(ie. what was the ecu doing to spoil the fun)
Old 12-24-2009, 09:49 AM
  #445
Boosted_Cobalt09's Avatar
bump for an update.
Old 12-24-2009, 01:33 PM
  #446
Matt M's Avatar
Getting past 400whp is mainly based on fuel system. Raising the fuel pressure was our solution.
The ECM is stingy from many angles. It only allows certain amounts of boost. It only allows certain amounts of airflow. Believe it or not, it only allows a certain amount of accelleration regardless of other variables. The charts we have access to are also limited in RPM range, so it is difficult to tune a setup running to 8000+ RPM.
Old 12-24-2009, 01:35 PM
  #447
mkriebs's Avatar
Have you guys tried running the GM stage kit? It seems much of the limiting parameters are different in the Calibration. I am going to give it a shot on mine, and see where it leads us. I think it is a partial cure for the throttle closing issue. I know it will let us get near 30psi.
Old 12-24-2009, 03:02 PM
  #448
Matt M's Avatar
I do hope to compare them soon if possible.
Old 12-24-2009, 03:11 PM
  #449
blownss06's Avatar
hope to see a full kit with pricing soon, sounds like a good way to bring in a new year!
Old 12-24-2009, 04:00 PM
  #450
mkriebs's Avatar
Good good! I think you could make much more reliable boost numbers on that. I doubt you would pick up more power, but you never know. I am not sure what other tables the GMPP tune modifies over the base map.
Quick Reply: ZZP LNF Turbo Upgrade- First Dyno Session
