ZZP LNF Turbo Upgrade- First Dyno Session
#76
yep. really all that needs to be done by somebody now is cams, a new intake manifold, a turbo manifold, and axles.... everything else is available,,,,, rods, pistons, bolts, gaskets, valves, springs, everything...
#78
I went to the shop today and made a few more pulls. It put down 468 at 22psi and then480 at 23psi. This pull was cut short by the ecm, only this time the throttle cut much quicker. There was also a bit of misfiring around 6700-6800 which you can see on the chart.
Can you guess when the throttle closed?
For the last pull, I bumped the boost to 24psi and started the pull a little later to see if the throttle closing was partly time based. It did not close rapidly this pull, but started tapering off at 7200 RPM. The misfires got worse, but it still put down 487whp sae.(514 uncorrected!) I think the plug gap needs to be tightened up. I will look into it tomorrow if I get a chance. I also need to figure out a way to tune above 7000rpm. It's tough when there are no airflow or fueling charts that go that high in HP Tuners.
Here is the dyno chart-
#79
S256 kinda simplifies things too since its a dry housing. It'll save some money on fittings. I think the only thing the 3076r has on the S256 is a couple hundred RPM (tops) spool. There was a time when the 3076r was quite a bit more than the S256, but it looks like they're about the same price now.
Once you get this dialed in I'd be curious what, if any, difference there would be if you put a .70ar housing on the hot side.
I'll also be curious what the pure pumpgas power will be.
Call me curious.
EDIT: Damn LNF PCM, ... HPT needs to unfuck it for us.
Call me curious.
#81
The LNF intake manifold is pretty good, but there may be small gains to be had.
Our kit will include a new turbo manifold.
LNF axles are very tough. They look like 3/4 ton pickup axles.
#83
Cams will be tough because if you lengthen the duration, the fuel injection window will be even shorter.
Have you guys looked into bigger/different injectors? There was someone on a speed forum and had a company that could make them but never got around to it...
#85
#87
#88
Rent me! per hour
ah ha, i see running off the map has more hidden issues in the lnf world.
under the assumption that the overboost/underboost codes are shut off, or set way out of bounds. did you tweak the optimum torque table way off scale from the stock ones? i remember someone else on here having a similar issue in the upper rpm range with the tb shutting them down due to this table.
dunno.
::shrugs::
as far as the gt30 choice? the BW turbos are waaaaaaaayyyyyyyyy better, then older garret tech
dunno.
::shrugs::
#90
I know you guys do FWD performance, but i would love to rock this turbo on my solstice gxp. any chance of that happening?
#92
But hopefully they do not just stop updating for the LNF because there are plenty of users that need their support!
#93
The mistake I see here is you only want to run some of our parts, there is a reason we are not running the gt stuff, and our cars are making more power than most. You should pick a shop and stay with them, not saying you didn't do that with hahn but it didn't seem to work out. If you want to make the power run our parts and don't try a hybrid parts build. The 3076r will not out perform the S256. Just a suggestion.
#95
#96
#97
