ZZP LNF Turbo Upgrade- First Dyno Session
Old 10-20-2009, 08:40 PM
  #151
HunterKiller89's Avatar
Originally Posted by CudaJoe
soooo what kinda valve springs/ rokcers/ cams do you guys have running with this setup? Surely those are gonna need some investigation for this engine to survive this turbo setup?
IIRC stock cams and other than valve springs its a completely stock valvetrain.
Old 10-20-2009, 10:17 PM
  #152
Matt M's Avatar
You can hire a guy for $50 bucks to make you a fantastic website no questions asked. you can make a good website and have a good company. Thousands of companies do it.
LOL. Fifty bucks for a website with 800+ products. I wish.
Originally Posted by NME
Are you guys using the 2.4 turbo down pipe or the lnf style?
No, it is a new downpipe, very similar to the twincharge downpipe.
Originally Posted by blackvette101
Is this turbo ball bearing? And will this be relleased before january? I will be doing a big turbo kit in january and this is the kit i want. You guys seem to be head and shoulders above every other big turbo kit on the market.
It is not ball bearing. We should have it out by January, but we don't have a date set.
78lb valvesprings. Cams and rockers are stock.
Originally Posted by WaRRioR-StaTuS
this thread makes me so happy, lol and I know there is alot of questions being asked and its hard to follow up on but your actually doing amazing job on that aswell lol
my only question is, i do have the hahn IC, DP, and Exhaust, how bad would it REALLY be to use this kit with my bolt ons? I mean its just exhuast, spooling differences will be minute...right? IC I understand but will ur piping fit, or sell sell sell then buy zzp? lol thanks and once again great job!
Your IC would work fine. The DP would need to be changed. The catback should work fine, but I don't know how big it is.
Old 10-20-2009, 10:29 PM
  #153
2K5SS/SC?'s Avatar
Damn impressive numbers! Very good work.
Old 10-20-2009, 10:30 PM
  #154
tomj77's Avatar
does the zzp downpipe throw codes at all? i might just get it.
Old 10-20-2009, 10:36 PM
  #155
Matt M's Avatar
Originally Posted by BYT*SS*TURBO
I agree, it took me a couple times to figure out it actually changed. On my HPT software, if I change the axis I have to close and reopen the table for it to display correctly. The first time I changed one of the axis' I thought it had no effect lol..
(Click there obviously)
(It brings up this table with the different RPM Points, change it as you need)
(You will have to close the table then re-open it for it to show the changes!)
Very nice numbers!!
I've done that, but it causes a serious glitch in the timing. It will drop to less than 10 degrees at 7500 RPM and lose over 100hp. It seemed as though extending the tables caused the EMC to look for another table or modifier that isn't there, causing a problem.
Old 10-20-2009, 10:44 PM
  #156
FutureEcotecOwner's Avatar
If you get one with a cat it shouldnt, or if you go catless order the angled O2 bung, and it wont.
Since you guys seem the most experienced with the SS/TC, what would be the highest you would raise your rev limiter? Right now mine is set to stock and it seems to work great. Guess my question should be, does the power fall off after 6300rpms?
Last edited by FutureEcotecOwner; 10-20-2009 at 10:44 PM. Reason: Automerged Doublepost
Old 10-20-2009, 10:45 PM
  #157
06black's Avatar
who would have thought a modern, DI, VVT enigne will make solid power with more fuel and a better flowing head!
lol. DUH.
nice work Gents, nice work!
the misfire issue is the same thing i ran across with a few of the big boost 30r cars.
Old 10-20-2009, 10:51 PM
  #158
Matt M's Avatar
On the stock turbo, I usually shifted around 6500 RPM. Power is pretty flat til a little past 6000, but then starts to taper off.
Old 10-20-2009, 10:55 PM
  #159
Thanks for the quick reply, and thanks for getting my catless DP to me so fast last week, LOL. I've heard different things about the rev limiter. I've heard leave it alone, and I've heard people say to raise it so you dont hit it when shifting fast. Either way, I might raise it just to have it raised.
Old 10-20-2009, 11:08 PM
  #160
Matt M's Avatar
After looking at the logs and studying the injector pulse widths and cam timing in the area of the misfires, I'm pretty sure that the misfire is simply the result of running out of the injector window once again.
Edit- math was wrong.
Old 10-20-2009, 11:09 PM
  #161
tomj77's Avatar
[QUOTE=FutureEcotecOwner;4394016]If you get one with a cat it shouldnt, or if you go catless order the angled O2 bung, and it wont.
which one is better hahn or zzp?
Old 10-20-2009, 11:10 PM
  #162
ZZP > Hahn
Both are good downpipes, but ZZP's is alot cheaper, and they are made really well. Just look what they're doing on the stock turbo with their parts, running 11's.
Old 10-20-2009, 11:16 PM
  #163
tomj77's Avatar
u had me at cheaper. lol
Old 10-20-2009, 11:19 PM
  #164
blackvette101's Avatar
So pretty much the only other aftermarket parts that will fit with this kit are catbacks and intercoolers. Or will other intakes and charge piping match up.
Old 10-20-2009, 11:20 PM
  #165
ZZP - $231.60 - catless DP with angled O2 bung for no CEL
Hahn - $324.99 - catless DP with angled O2 bung for no CEL (this is without the taxes and shipping too)
Old 10-20-2009, 11:22 PM
  #166
tomj77's Avatar
i guess zzp it is. maybe with an extra o2 bung just in case
Old 10-20-2009, 11:26 PM
  #167
pookie025's Avatar
will dejon dp work with this setup
Old 10-20-2009, 11:27 PM
  #168
Unless you are monitoring your stuff with a scan gauge, I dont think you really need it. But I could be wrong.
Old 10-20-2009, 11:33 PM
  #169
Matt M's Avatar
500whp dyno chart from Monday. You can see where it was misfiring a little.
We also put down 495 through the full exhaust today.
Old 10-20-2009, 11:37 PM
  #170
berto's Avatar
Originally Posted by Rissa
Black ones are the best ones haha.
YEsssssssss!!!
  #171
Kildore's Avatar
Thats awsome! Looking forward to some testing..and endurance of the motor itself under some extreme conditions and many laps down the track.
Old 10-20-2009, 11:45 PM
  #172
Matt M's Avatar
Charge tubes and ICs will still work, as well as catbacks.
  #173
jvc06sc's Avatar
I really want to see this car run Ryans car. Nice work guys!
Old 10-20-2009, 11:53 PM
  #174
berto's Avatar
I might be inerested in your guy's catless d/p
i loved ur header/down pipe combo for my old SS/SC
so im sure ur d/p for my SS/TC wont disapoint me...let me get pAid
Old 10-20-2009, 11:58 PM
  #175
Rissa's Avatar
Lol I like your lil misfires
Quick Reply: ZZP LNF Turbo Upgrade- First Dyno Session
