ZZP PCM Install
Old 10-11-2010 | 06:26 PM
needmocheese's Avatar
ZZP PCM Install
tried installing it on my cobalt(2009 SS) this weekend and not letting my car start. Went through the whole security check thing, still nothing, and the security light isnt on anymore.
Any ideas??
Ask questions if you need more info to help me get this working
works fine with old PCM
thanks
Old 10-11-2010 | 09:45 PM
no one eh??
would be nice if zzp would chime in since i already emailed and called a couple times...
Old 10-11-2010 | 10:59 PM
RossGo's Avatar
Mine took a long time. You have to turn the car to on, and wait until the security light flashes (about 15 min). You then turn the car off and repeat another 2 times. Then start it and it should work.
If that doesnt work, PM me
Old 10-11-2010 | 11:01 PM
i did what the website said, now the security light doesnt come up when i turn the car on, your saying to do this ontop of this??
website sayed to turn car on, let it sit for 10 min and the light goes off, turn off and repeat a couple of times
Last edited by needmocheese; 10-11-2010 at 11:01 PM. Reason: Automerged Doublepost
Old 10-11-2010 | 11:03 PM
btw how do you like the tune?
Old 10-11-2010 | 11:10 PM
RossGo's Avatar
I am not sure what the site says.
I believe I was the first person to have their tune on a different PCM, so we both had a hell of a time.
I got mine to have a spare PCM, and to have a good base tune until I got all my parts.
I couldn't have been happier with it, but I did just tune over it last week with TF, to actually "tune" for my parts.
It is VERY comparable to the GMS1 parameters I now run as my base tune, and was excellent for a mail tune
Old 10-11-2010 | 11:12 PM
so your saying, turn the car on, no light shoul dbe lit up, wait 15 minutes, should start blinking, redo steps
Old 10-11-2010 | 11:39 PM
RossGo's Avatar
When you turn it to on, without starting, the security light should be SOLID. After a period (~15 min) the light will go off and begin to flash. After 2 or 3 flashes, turn the car off, count to five, and repeat twice.
Ill check for my email from stattama, but that was a long time ago, and I am nearly positive it is far gone
Old 10-11-2010 | 11:47 PM
That's where my problem is, I did that, now there is no light. And it doesn't turnover, or try to start.
After 10 minutes or so light went off, then repeated like 5 times. Light doesn't show anymore and car doesn't start =\
Starts right up with old pcm
Last edited by needmocheese; 10-11-2010 at 11:47 PM. Reason: Automerged Doublepost
Old 10-11-2010 | 11:48 PM
Old 10-11-2010 | 11:52 PM
RossGo's Avatar
Maybe five times was too many?
No security light shows at all now?
Old 10-11-2010 | 11:55 PM
colodude18's Avatar
Are you turning the ignition off for 5 seconds before attempting every restart? This is what they told me when my security light wouldn't come back on after the second try...
__________________________________________________
Black 2010 SS/TC – G85 |Debadged | GMS1 | Hahn 3” DP and Catback | AEM intake | GM racing pedals | OZ Ultraleggera rims |DEPO 4th gen projectors w/ 6K HIDs | smoked LED tails | 20% 3M tint |Pioneer Avic Z110bt head unit, Alpine PDX-5 amp, Focal speakers all around
http://www.cardomain.com/ride/3835837
Old 10-12-2010 | 12:03 AM
colodude, did your light ever o back on??
ill try this 5 sec rule, didnt before
Old 10-12-2010 | 12:23 AM
RossGo's Avatar
I think that is key. I was gonna say count to ten, but I couldn't remember for sure haha
Old 10-12-2010 | 12:27 AM
trying it as we speak
Old 10-12-2010 | 12:45 AM
im on the 3rd try and still nothing, im hoping the next one works...
Old 10-12-2010 | 12:47 AM
colodude18's Avatar
In my case the light came on after installing the PCM after the first start attempt. Then, after the light went out after 10 minutes, attempting to start it wouldn't make the light come back on. Turns out I forgot to turn the ignition off, wait 5 seconds and then try to start. That made the light come back on in my case, and started the car on the 4th attempt (after 3x 10 minute-wait)
Old 10-12-2010 | 12:54 AM
colodude18's Avatar
And?? Did it work on the 4th try??
Old 10-12-2010 | 01:01 AM
nope, gonna go do the 5th and final try in about 2 minutes, i have no light to direct me when the lights goes off lol
Old 10-12-2010 | 01:04 AM
colodude18's Avatar
You shouldn't have to do it 5 times. Did the light stay out after your 4th start attempt? Mine did and I had to try to start a few times (turn ignition off, wait 5 seconds, and start) You shouldn't have to wait 10 minutes for a 4th time!
Old 10-12-2010 | 01:09 AM
yea the light has been out this whole time
i just tried turn on,off, wait 5, on, doesnt even try to start, starter doesnt click or anything...
still not starting btw lol
not sure what to do
Old 10-12-2010 | 01:15 AM
colodude18's Avatar
I suggest you try it again from scratch tomorrow. Once the security light stays out, you should notice a difference when you try to start. It took another 4 tries after that for me but the good thing is once it starts once, it will always start after that... Good luck and let me know how it works out. If it still doesn't work, contact Matt at ZZP (stattama@aol.com).
He's been very helpful to me. Now go to bed, its after midnight by you!
northvibe's Avatar
here is the security relearn:
1. Depress the clutch and try to start the car. If it does not turn over, let off, but leave the key in the run position. The security light should be lit up on the dash.
2. Wait 10 minutes(you can open the door and get out). The security light on the dash will turn off after 10 minutes.
3. Turn the key off for 5 seconds, then depress the clutch and try to start the car. If it does not turn over, let off, but leave the key in the run position. The security light should be lit up on the dash.
4. Wait 10 minutes(you can open the door and get out). The security light on the dash will turn off after 10 minutes.
5. Turn the key off for 5 seconds, then depress the clutch and try to start the car. If it does not turn over, let off, but leave the key in the run position. The security light should be lit up on the dash.
6. Wait 10 minutes(you can open the door and get out). The security light on the dash will turn off after 10 minutes.
7. Turn the key off for 5 seconds, then depress the clutch and try to start the car. The car should start on this attempt.
There is also a case relearn, where you rev the 2k rpm and let off
Old 10-12-2010 | 01:17 AM
yea this is what i did
then the security light went out
but it doesnt start
Old 10-12-2010 | 01:24 AM
**** sleep, i want my **** to work lol
