ZZP PCM Install
Old 10-12-2010 | 10:21 AM
superbrowndude's Avatar
Any luck today ?
Old 10-12-2010 | 12:00 PM
needmocheese's Avatar
Can't try til later, working
Old 10-12-2010 | 04:30 PM
Matt M's Avatar
Do you have any way to check for a code? If so, check that and let me know what you find. Email me at stattama@aol.com. If there are no codes, unhook the battery for a half hour and try the relearn again. Try to start the car each time you turn the key on. Wait 10 minutes, turn key off for 5 seconds and try to start it again. It should start on the 4th try. Everyone that reported that it wasn't working eventually got it to work, so it has to be something in the process.
Old 10-12-2010 | 06:37 PM
vahdyx's Avatar
Hope you get it to work, I've been considering this mod for months, but never pulled the trigger.
Old 10-12-2010 | 07:13 PM
Ok well I tried it again with no luck, is there anything else I can do?
could it be the pcm?
Old 10-12-2010 | 08:02 PM
colodude18's Avatar
Take a drive to ZZP, I hear the Blue Ridge Parkway is awesome this time of year
But seriously, it sucks that it doesn't work. are you sure you're following all the steps in the right order? Does the security light come on after each 10 minute wait or just the first time?
If the light doesn't even come on after the very first start attempt, it could be that the relearn is already done. Once I got mine to work, it was (and still is) a little temperamental. Sometimes nothing happens when I turn the key and it takes a second or even third try, but it alway starts eventually. Have you tried that??
__________________________________________________
Black 2010 SS/TC – G85 |Debadged | GMS1 | Hahn 3” DP and Catback | AEM intake | GM racing pedals | OZ Ultraleggera rims |DEPO 4th gen projectors w/ 6K HIDs | smoked LED tails | 20% 3M tint |Pioneer Avic Z110bt head unit, Alpine PDX-5 amp, Focal speakers all around
http://www.cardomain.com/ride/3835837
Old 10-12-2010 | 08:13 PM
vahdyx's Avatar
I'd say you may have a defective PCM, if I were you I'd call ZZP and return the PCM and get a new one.
Or
Ask them to help you with the relearn
*side note*
V8This I think I saw you on 36 and Wadsworth, I was visiting my friend and I saw a Black SS with black wheels get on 36 headed towards flat irons mall
Old 10-12-2010 | 08:29 PM
Chevycobaltss3's Avatar
did you do what matt said to do..... if not do so... Check for a code if possible. if your car has the clutch peddle switch code your car wont turn over because of it bein g in limp mode. do the battery if so.
Old 10-12-2010 | 08:53 PM
all the normal lights come up when i turn the ignition on
the security light DOES NOT light up
and yes i did what matt told me to do on point
the thing is there is no light, so i just turned it off every 10 minutes, gonna try it again in 30 min or so to see if it will go.
as for the codes, i have no clue how to do that
and when i put the stock pcm back in, starts first try without a hickup...
oh and ive tried calling zzp, always get an answer machine, left 2 messages within the last couple of days...and an email
security light doesnt come on at all when i turn on the car
Last edited by needmocheese; 10-12-2010 at 08:53 PM. Reason: Automerged Doublepost
Old 10-12-2010 | 09:08 PM
vahdyx's Avatar
What kind of phone do you own? Reason why I ask is because you should record yourself and post it on youtube then post the link here of what you are doing. That way we can help you out with visuals.
Just a suggestion
Old 10-12-2010 | 10:01 PM
  #36
Matt M's Avatar
You didn't check for codes and you didn't send an email to the address that I gave you in this thread. Zoom got the message, asked me about it and I told him not to worry about it because I gave you my contact info in this thread.
Old 10-12-2010 | 10:13 PM
  #37
how do i check for codes?
Old 10-12-2010 | 10:24 PM
  #38
can you call me or instant message so we dont have to talk through this thread of email??
Old 10-12-2010 | 10:32 PM
  #39
troyss's Avatar
Put your stock pcm in and drive to autozone or advanced auto then switch to your zzp pcm and ask the cashier to scan your car for codes or if you have an interceptor installed in your car you can tell that quick
Old 10-12-2010 | 10:35 PM
  #40
wouldnt a light pop up if there was problems with something though??
Old 10-12-2010 | 10:38 PM
  #41
troyss's Avatar
Yeah I would think so but your car isn't started all the way up to tell with the zzp pcm
Old 10-12-2010 | 10:55 PM
  #42
gotcha, I'm gonna try this relearn process again tomorrow, if it doesn't work for the 4th time, ill try to get them to look-up any codes.
this is BS, I'm so excited to get it going lol but yet it doesn't wanna work =/
i'm not blaming zzp, just sucks
Old 10-12-2010 | 10:57 PM
  #43
troyss's Avatar
I bet man it would suck but just think it will work soon and your car will be so much better..
Old 10-12-2010 | 11:09 PM
  #44
colodude18's Avatar
You SHOULD be excited. I just put in my ZZP PCM today (I only use it occasionally) and it's always amazing. Don't know if you have GMS1, if you don't you'll **** your pants, lol. But even compared to GMS1 this has so much more torque, If I'm not gentle on the throttle I'm constantly spinning tires in second gear and chirp occasionally in third!
I'm sorry, i didn't mean to make you more frustrated, just think about how it'll all have been worth it once you finally get it to work!!
  #45
got a track day next sat, hopefully it will be working by then
Old 10-13-2010 | 05:10 PM
  #46
ok well i got it to work today miraculously
went to autozone to get the codes checked, didnt show any codes, go into the car just to give it one more try to start, starts on first attempt.
so thanks everyone for the help, not sure what i did different today but it worked.
Old 10-13-2010 | 05:16 PM
  #47
vahdyx's Avatar
I hate it when things happen this way, I'm thankful when it does but damn the road it took to get there especially without explination.
You'll have to tell me how it works.
Also do you have GMS1 Sensors
Old 10-13-2010 | 06:45 PM
  #48
no sensors, dont have the cash to pull for those things, plus im not doing anything ontop of this tune.
so far so good, lots of traffic out so cant really test it out till tonight
Old 10-13-2010 | 07:39 PM
  #49
colodude18's Avatar
That's great news man, perseverance paid off!
Now find a stretch of open road and start saving up for new tires
Old 10-13-2010 | 09:45 PM
  #50
i have to jam the clutch to the floor to get it started, that was my problem, is there a way to adjust it so i dont need to smach it to the floor?
seems like a hair off and it doesnt start
