ZZP SS/T Dynos 403 WHP!
Old 03-31-2009 | 11:19 PM
Matt M's Avatar
In the interest of conducting research for our LNF turbo upgrade, we installed a ZZP turbo manifold in place of the stock manifold and bolted up a Bullseye Power S256 extended tip turbo. It is basically the same as our twincharge turbo, except for a smaller exhaust housing. We quickly got into the 370whp range, but then we began battling the ECM and all of it's abilities to veto anything radical. We hit 390whp on 93 octane, but ended up putting in some 110 because we figured we'd be making a lot of pulls and didn't want to risk a 4k mile LNF motor this early in the game for us. Many pulls later, we surpassed 400 with a clean 403WHP at 24psi. FWIW, this was done with the factory airbox with a custom short ram intake tube, drop-in K&N, and inlet tube mod.
We will be racing this car soon, but I'm afraid that I'm going to have a lot of difficulty getting down the track. The boost hits way too hard to feather the throttle for moderate power. I'm hoping to set up a multi-stage or progressive boost controller to keep the tires from going up in smoke until half-track.
Any guesses what times/mph it will run? Keep in mind that I have very little experience drag racing a manual trans car. I also won't have the luxury of having 28" tall slicks and wheelie bars like I do on the Grand Prix. I might not do so well the first time out.
Old 03-31-2009 | 11:40 PM
steddy2112's Avatar
14.xx@ 118ish
Old 03-31-2009 | 11:41 PM
Sentry's Avatar
Either way, that's awesome! Keep up the good work.
Do you have a dyno sheet for us to look at?
Old 03-31-2009 | 11:42 PM
1WhiteSSTC's Avatar
Originally Posted by steddy2112
14.xx@ 118ish
rite........i'm thinkin more like 12.xx@115-125
Old 03-31-2009 | 11:43 PM
steddy2112's Avatar
I think he spins through 3rd.
Maybe 13s
Old 03-31-2009 | 11:46 PM
Smarty Art's Avatar
12.7 at 118
Old 03-31-2009 | 11:48 PM
PimpLay2's Avatar
i say 13.2-13.5 @ 115+
good driver def 12.8
Old 03-31-2009 | 11:49 PM
tomj77's Avatar
since my friend has a 400hp civic and getting in the 11's im thinking 11.xx if he can put the power to the track instead of up in smoke.
SSdan's Avatar
12.8, 120mph.
Old 04-01-2009 | 12:03 AM
agent007kimball's Avatar
12.5 @ 122
Ending the race close to redline in 4th
Old 04-01-2009 | 12:08 AM
FF_ace's Avatar
lets see your dyno graph
Old 04-01-2009 | 12:10 AM
LaserblueSS's Avatar
wow. 400 ponies under the hood with very few mods... i have turbo envy. good work guys.
Old 04-01-2009 | 12:16 AM
Luv2Race's Avatar
at 320 whp with no traction i ran a 13.4 @ 116mph
Old 04-01-2009 | 12:26 AM
steddy2112's Avatar
Originally Posted by agent007kimball
12.5 @ 122
With that turbo and tuning the redline should be raised.
Probably revving it out to 7200
Old 04-01-2009 | 01:25 AM
elecblue06's Avatar
24psi?
using a map clamp?
nice numbers
got any graphs with stock over lay
Old 04-01-2009 | 02:07 AM
Mazdaboi318's Avatar
11's should be there!! come on
Old 04-01-2009 | 10:58 AM
Matt M's Avatar
12.5 @ 122
We were dynoing up to 107 in 3rd, so 4ths redline should be in the 130s.
Originally Posted by elecblue06
24psi?
using a map clamp?
nice numbers
Regulators. What we really need is more PCM access so we can alter the MAF delta limits. Every time this turbo hits hard it closes the throttle instantly. We have to bring in boost progressively. It works, but the torque numbers are only in the 360-380 range when we do this, depending on how quick we bring in the boost. When we let the turbo hit, torque was over 400 just before shutting down.
I'll get some dyno graphs printed today.
Old 04-01-2009 | 11:00 AM
Dustinss's Avatar
11s with dr
Old 04-01-2009 | 11:01 AM
Matt M's Avatar
I think that will take better tires.
Old 04-01-2009 | 11:02 AM
umrdyldo's Avatar
This car sounds like a beast. Vids or graphs would be nice.
Old 04-01-2009 | 11:03 AM
widowedeight's Avatar
12.3 @ 124....... do i get anything if i win?
like...... i dunno...... the turbo kit?
Old 04-01-2009 | 11:05 AM
Terminator2's Avatar
I say 12.5 at 120mph
Old 04-01-2009 | 11:11 AM
KyleMinnis's Avatar
12.5 @ 122
thats what i was thinking...ishhh
Old 04-01-2009 | 01:16 PM
eiuprtycntrl's Avatar
you better be looking at full out drag slicks
Old 04-01-2009 | 02:02 PM
Zander916's Avatar
I was thinking the same.
Quick Reply: ZZP SS/T Dynos 403 WHP!
