ZZP SS/T Dynos 403 WHP!
#127
since you know so much why dont you explain to all of us why no-one has done it yet then...???
what you dont know is he was running a power adder... so watch what you say, fool. do your homework and get off his nuts
id say he was around 320 when he did that... (hint)
actually come to think of it this is the second retarded thing you said in two days, im have to throw you on the ignore retarded css.net members list
for one thing your ricer math dont add up... and for another thing i clearly see you dont know the difficulty between a low 12sec pass and a 11sec pass that my friend is a giant hurdle for the fwd coby...
its not about power...
hp to weight... it's math not ricer math... if a GTO can hit mid to high 12's with 350 whp (ls2) .... then take away 800 lbs and add slicks or DR and some drag bags to reduce squat and tell me why we cant run 11's with the same whp... every 100 lbs = about .1 off your 1/4 mile..
and you say hatrickstu used a power adder... 1.)hatrickstu,12.756@108.92 w/1.936 60' 2.85/I/H/DP/CD/E/T/CM/WR/SM/DR's then i guess this needz to be changed because aside from heavy suspension mods and a medium sized pully and bolt ons theres nothing crazy here... he's said multiple times he ran that with about 260 whp... or so
get off your high horse 11 second pass is a matter of traction.. not power.. case and point
go fail someone else.. not to mention you say i dunno what i'm talking about however you said that sportredss has brains and he's pretty much been certified as not knowing wtf he's talking about...
fuel pump is not an issue.. leave it to people who actually have worked with these cars... and if steveo thinks that the fuel pump is the issue.. then thats just another reason for him to be discredited
#128
Damn Michigan weather. This week looks decent up this way so possibly numbers before memorial day?
#132
I was one of the first to get it to...btu that doesn't mean anything other than I spent double on it
#133
#135
We tried to run it a few weeks ago on the stock clutch and it didn't happen. It toasted the clutch right off the bat. We found out afterwards by checking the logs that it was running almost 30psi boost, so it was not surprising. We now have a ZZP S4 clutch in it, but it's back on the stock turbo.
#137
#138
#140
We should have the turbo upgrade setup available fairly soon. We have been trying to keep up with 2.4 turbo kit sales, twincharge sales, and 3800 turbo kits , all of which have been selling very well.
I've also been throwing around the idea of a twin turbo setup for the LNF.
#142
We had regulators on the MAP sensors set at 20psi. We had to check the dyno logs for comparison and found that we were running over 45lbs/min when the clutch let go.
#144
We worked out a deal with a reputable clutch manufacturer. I'm not sure how much info is being released yet, but I can tell you that I have been quite impressed. While logging some test runs on the street, I saw a drop from 6900 RPM to 4300 RPM in 1 frame on HP tuners between the 2-3 shift at 20+ psi.
