05 cobalt ss sc misfire at operating temp, tried everything!!
You could always do trifecta. He ships you the cable to load the tune, for a fee, and then refunds you the fee for the cable or you will need to find someone with HP Tuners
Ah ok we're thinking outside the box enough now haha but why would it only start skipping once the motor warmed up to 151degrees? Because it goes into closed loop and the sensors start picking up the different intake?
I had the same thing happening to me. Replaced everything i could. Come to find out my injectors were getting plugged with nasty dirt powder.. Check your fuel rail for some nasty dirt powder,and pulse the injectors and back flush them out.
This was on my 07
This was on my 07
#36
[QUOTE=Team SS;6797184]lol
Yes you do.
when Replacing the cam Sensors, You HAVE to Relearn them.[/QUOTE
there is only one cam sensor you dont need to relearn when you replace it the crank it is supposed to have a relearn now plenty of people have replaced the crank sensor and not had to do a relearn the only time you need to do a relearn is if it is throwing the code for it
Yes you do.
#41
Lacking in sleep at the moment, being high would be more fun lol. My bad i ment plugs, hard to see what im typing on my phone. Which ngk plugs are u using, and what kind of intake? Just curious
#45
TLDR. All ima say is u need thre3 things to make an engine wang. suck, squeeze, bang, and blow. you aint got one of those bitche$ and the $hit aint nakin powA. Put some redline oil in itl, and just throttle through the misfire. I would also put some platinum plugs in it to make sure that max boost is hit before knock retard.
#46
I agree ^, I bought new ngk's gapped at .044" and misfire is gone. I would regap those plugs.
#47
LoL ^ mine did the same ****! parden my french but my bolt got lodged between the timing chain, and the side wall thank god it didn't bust my chain.. glad to see GM made that a common issue for us.. wtf.. And its a loud tick.. mine sounded like a VW diesel...
Getaway_Driver
09-08-2015 09:41 AM
