06 ss loosing 3lbs of boost
my car ran a consistant 12lbs of boost. i put on an intake and now when i get up around 4500rpm's or higher my boost falls down to about 9-10. it never did that it was always consistant. i checked for leaks but don't believe i have one anywhere. anyone have a similar problem with an intake install? i got a check light a few days after putting it on. i disconnected the battery for a bit and cleared that. but how would it make me loose boost. some help
i have no idea on elevation. and someone last night told me on here to disconnect my battery and i did. so now the code is cleared and i can't pull it to even know what it was.. i'm 99.9% it is intake related since i just put a new one on a couple days ago. i'm sure the light will come back on again. i checked and have no leaks.. the throttle seems a little jerky at lower rpm's.idles fine. once i'm in boost its fine besides loosing a few lbs at high rpms which my mechanic told me is actually quite normal on a sc car. but it didn't do it before the intake. i had some ******* say send your intake back but...i don't think the manufacture of it would make a difference.. its a piece of pipe. wether or not it has to learn the new air flow i dunno. i've always had fords.
