15lbs boost
Old 03-30-2007 | 09:54 AM
supersexycobalt's Avatar
15lbs boost
i got a K&N intake a catback exhaust and stage 1 and when i get on my car the boost gauge reads almost 15lbs of boost does this seem right
Old 03-30-2007 | 10:01 AM
yellowcobaltss05's Avatar
no you should be around 12-13 but maybe your boost gague is off or your cat is clogged.
blacksssc06's Avatar
well lets see here i have a 310 pully and a injen intake and a flowmaster muffler and im makeing 15 16 psi on stock injectors. so if the pully still stock than yea i guess that would be right
Old 03-30-2007 | 10:02 AM
our cars boost 12-12.5 STOCK
Old 03-30-2007 | 10:10 AM
ImaginaryForce's Avatar
Keep in mind the stock boost gauge is electronic so being inaccurate is not uncommon. On my stage 2 I saw 14 lbs of boost and with a mechanical gauge I saw 16-17. I've also noticed temperature can affect how much boost it will show. If you were truly curious you could put a t-bracket into some vac line and run a mechanical gauge for a day or just switch to one altogether.
Old 03-30-2007 | 11:00 AM
Ryuu600's Avatar
As said the gauge is crap and a clogged cat will cause this also.
On the mechanical gauge... is there a good way to stop the "buzz" completely. I had an autometer in my Passat and for the first 10k miles it was fine then all of a sudden one day it started buzzing, very annoying.
Old 03-30-2007 | 11:07 AM
how do i know if my cat is clogged
Old 03-30-2007 | 11:45 AM
06_SS_S/C's Avatar
I think I might be experiencing this buzzing noise too...only certain times, when I accelerate it will sound almost like a ringing noise, like a small bell. It is very annoying...it started right after I put the mechanical one in, so I figured it was related. I was going to try and look at it this weekend and see if I could figure out what the deal was...
Old 03-30-2007 | 01:09 PM
zinner's Avatar
Moderator Alumni
electric/digital > mechanical
Old 03-30-2007 | 03:18 PM
Ryuu600's Avatar
Antibuzz fitting
That T-fitting has a restrictor in it that will help eliminate the buzz.
Old 03-30-2007 | 03:20 PM
06blackg85ss's Avatar
I'll post a log tonight... stock pulley, injectors, tuned with intake hit 14.88 psi.... (not cat either)
Old 03-30-2007 | 03:26 PM
06_SS_S/C's Avatar
Antibuzz fitting
Awesome, thanks. I was reading up on this today and found a similar product someone else was selling for $20. I sent Autometer an email, hoping they might have something like it for cheaper. I might just go ahead an order this one. Seems like it will fix the problem...
Thanks again! +rep
Old 03-30-2007 | 03:29 PM
Super_SS's Avatar
okay i got a questionn...on our stock boost gauges...where should the need be at WOT on a STOCK car...1-2 lines before 15psi?
Old 03-30-2007 | 03:31 PM
Ryuu600's Avatar
Honestly you could build this from Home depot tubing for pretty cheap too. take a piece of plastic tubing with an outer diameter that matches the inner diameter of your t-fitting and has a small inner diameter like 1/8 or 1/16 and cut a small piece and glue it into your t-fitting on the side where your gauge line hooks up.
Old 03-30-2007 | 03:35 PM
ItalianJoe1's Avatar
Want to buy a Mech boost gauge??
https://www.cobaltss.net/forums/parts-66/gauges-tires-52530/
turbochargedss2012
09-20-2023 12:17 PM
Sl0wbaltSS
11-21-2018 11:11 PM
01-12-2016 12:01 AM
tomj77
10-04-2015 11:39 AM
717ssbalt
10-02-2015 04:01 PM
Quick Reply: 15lbs boost
