19 WHP camshafts for 2,0 Cobalt SS Supercharged !!!
Old 10-16-2005, 05:07 PM
UtOhCop's Avatar
Originally Posted by Jmc007
Crane camshafts are for the 2,2 Ecotec, but J-Body camshafts are for the 2,0 Supercharged LSJ Ecotec !
Comp can grind you cams for the LSJ
http://www.*************/forums/showthread.php?t=2164
I always mix up crane and comp
Old 10-16-2005, 05:24 PM
Jmc007's Avatar
This post (COMP cams) was about the 2,2 Ecotec ...
Old 10-16-2005, 05:35 PM
eastcoastz's Avatar
How is the cam install on our cars? I've done one on a Honda B16. I hope its not as bad as my Cavalier 2.4 was.
Old 10-17-2005, 11:19 AM
VaMP's Avatar
It doesn't say that it includes the adjustable cam gears, so that might be something else you'll have to purchase.
Old 10-17-2005, 12:32 PM
KnightRider7900's Avatar
guys i really dont think that a s/c car with a max of 18psi will get that much from cams. i have been suprised befroe with gains from things but it just is too much. it isnt as easy as opening up the valves longer as in an na car. cars that come stock with fi are pretty efficient when it comes to their cams unless u have a lot of boost. u guys will get something, but unless ur over 20psi, i think the gains will be more like 10whp. just my 2cents.
Old 10-17-2005, 12:40 PM
95cobra68camaro's Avatar
i cant imagine it being tooo hard to do cams, in reality all u need to is line the cmaes up dot to dot liek a honda loosen the tensioner and slip off the belt, place new cams in, re torque them and reverse process...imm assumn this b/c iv honda a 1000 hondas
Old 10-17-2005, 04:56 PM
silverSS's Avatar
b/c uve honda a 1000 hondas...interesting
jp man
Old 10-17-2005, 05:04 PM
sry about the typo i am at work so i had to type fast, iv done 1000's of honda cam swaps is what i meant to say but iv worked on a few newer ecotec's and fomr what i can remeber i dont think it should be that hard
Old 10-17-2005, 05:09 PM
BullDog71ss's Avatar
I'm not playing down the gain from the cams, but I'd be pissed if I spent $350 plus on a cam for my small block 350 and only got 19 whp, let alone $600 plus like these cams. I may look for cams later on, but imo the best bang for the buck mod right now is the revitup pulley kit. Less money, more power to the ground. Cranking up the boost is the way to get maximum power from boosted cars, cams will do little compared to more boost...untill the blower is maxed that is.
Old 10-17-2005, 05:31 PM
VaMP's Avatar
Cams really aren't all that hard, it'll take a whole days work to do it though. Do we even know if these cams run on our cars without throwing a whole series of codes?
Old 10-17-2005, 05:55 PM
  #36
Jmc007's Avatar
Here is the answer of JBody to a e-mail I wrote to them:
We are actively seeking new cars to test our camshafts on! Excited as we are, we only have one customer to date with our 2.0L SC camshafts.
They are working flawlessly in his car, with no codes and no issues. (We also hope it stays that way!)
As of now, we are concentrating on the Cobalt... and are trying to purchase a brand new one to perform our planned modifications on.
Thanks,
JbodyPerformance
Old 10-17-2005, 07:47 PM
  #37
snapb1's Avatar
I think you guys will see nice improvements from cams. From the look of these cams, low end is what they are more focused on, not top end.
Emissions shouldn't be a problem nor throwing any codes. Might have to adjust the idle a little though, but that is easy to do.
If anyone wants someone to put them in and is around the GA area, I am more than up for it.
Old 11-14-2005, 09:44 PM
  #38
Jmc007's Avatar
Anyone got stock cams replaced on the SS / SC ?
Old 11-15-2005, 06:58 PM
  #39
dirtySSout's Avatar
Thumbs up Go COMP CAMS
Go wth comp cams! There specs are 423 in./436 ex. lift 210 in./218 ex @ .50 lobe sep is 113. Less lift than JBP both increased duration,which is more important!!! And their factory price is $479. Better cam, better price! Also designed to work w/ all factory valvetrain!
Old 11-15-2005, 07:29 PM
  #40
3fo893013L's Avatar
We have too much low end stock hence the wheel hops on take off. Granted, the torque braces will help but we need more top end.
Old 11-15-2005, 08:28 PM
  #41
NGalaxyTimmyo's Avatar
https://www.cobaltss.net/forums/show...ight=300+build
Heres a link to all 4 parts on the 300+ HP build book. They talk about changing cams in one of them
Old 11-15-2005, 09:13 PM
  #42
xskier874's Avatar
nice!
Old 11-15-2005, 09:33 PM
  #43
phxSS's Avatar
Yea, it's the emissions thing I worry about. And they've only experimented on one SS. I would wait a while to buy them.
Old 12-04-2005, 01:56 PM
  #44
spooler's Avatar
hey guys, just thought I'd post a little update as to the cams; being the only one i know of with them. in the cold weather there's even more power from 2500rpm to redline and It feels as though the rev limiter is a bottle neck in making more power. so far, im interested in finding a way to bump the limiter up 500rpm or so. all i can say so far is money well spent, there's no codes and a lot of exhaust tone differences. to date, i have intake, cams and am working on saving for a psi-fi kit. i think with this current combination, i should be able to hit 250-260whp if i take it to the dyno. i cant keep the tires from lighting up. not bad for only $1000 invested into the car. and witht eh psi-fi, I should be able to get even more power out of the car.
Old 12-04-2005, 02:05 PM
  #45
Jmc007's Avatar
Have you done some before and after dyno runs with the cams ? What were the numbers, what was the dyno ? In 3th gear or 4th gear ? Thanks !
Old 12-04-2005, 07:02 PM
  #46
Tofu's Avatar
So tuning is not required when running these cams from jbody?
Old 12-04-2005, 08:26 PM
  #47
stuffy236's Avatar
tuning is required for ANYTHING you do to get the most power out of it.
Old 12-04-2005, 08:44 PM
  #48
SuperchargedSS's Avatar
These look really nice. I will be keeping an eye on these, no doubt.
Old 12-05-2005, 12:30 AM
  #49
Tofu's Avatar
Uh yes I know that, I'm not talking about getting the most power out of it, I'm talking about simply installing it and having no problems like idle surges or stalling out when turning on the AC etc.
GaryGibblez
01-14-2020 10:35 AM
Sean Cummings
09-11-2015 09:35 PM
Josh@ottp
09-08-2015 10:18 AM
medic710
09-06-2015 08:53 PM
Quick Reply: 19 WHP camshafts for 2,0 Cobalt SS Supercharged !!!
