2.0 turbo baby!!
#201
#203
Looks good.1 question.When you change your oil,do you have to remove the throttle body/adapter to remove the oil filter?Do you have anymore pics of the pulley they used to bypass the s/c?
I dont know how they did it with this kit,but..On the solstice forum,they welded a fitting on it,and attached the brake booster vacuum hose to it.That was a pretty good idea.
#204
#205
#208
#213
Mine is the 2nd car to dyno. Remember this is a load based dyno (Think Mustang dyno)
http://www.youtube.com/watch?v=gPUFP1Xk2tM
Dan
I dont have sound a work so I dont know what it sounds like.
Dan
#216
#219
LSX RWD S/C conversion
Dan
Dan
#220
2500 for all charge piping and full 3" stainless exhaust and clutch and axle install (also included heat wrapping and oil lines)
400 for turbo brand new
150 for wastegate brand new
50 for BOV rfl knockoff from ebay
50 for boost controller used
100+ misc flanges ebay
So under 4k to get the turbo kit designed and put on. But the mechanic said if he would do it again hed charge a lot more (another grand or so) because of the complexity of side mounting the turbo since it wouldnt fit behind the motor. When he originally quoted it we were mounting it behind the block and he stuck to his quote for me cause i took care of him.
If u used a smaller turbo thatd fit behind the block i see no reason y u couldnt come in under 4k....I technically did...but my turbo is way cheaper then most other turbos ur gonna find.
the other stuff like the eletronic cutout, axles, exedy, gauges cost a lot tho
#222
its all custom
#223
Pics and crap here:
https://www.cobaltss.net/forums/show...t=turbo+update
Dan
