2.0 valve cover gasket ....is it re-useable
Ive never had the valve cover off my car and I dont want a simple project to turn into a mess today because I cant get gaskets locally today . Alot of the new GM valve covers gaskets are re-useable rubber ones or re-useable 0-rings . Is the 2.0 gasket and spark plug hole gaskets re-useable or are they the old school 1 time your done ?
Check your PM's bro! For everyone else though, I reused mine and it works great. Just wipe down the gaskets clean, and ensure the cylinder head mating surface is clean as well. No leaks!
Make sure you use the Proper Torgue setting! Is a Rubber gasket only need to Torgue it to 89 lb in. 89 lb in = to 7 1/2 Ft lbs
You Do NOT have to remove the Fuel Rail!
Removal
Reeplacement!
Removal
Reeplacement!
Replaced Several of these Here Local & Some Members elsewhere! There is No Problem for Reuse, Unless rubber is Crushed or Damaged from over Thighten or You have alotta of Miles, Then I would replace the Gasket! The Torgue Settings are so Light, That It Should not ever warp the Valve Cover!
PS: Even Gm Doesn't call for replace! Unless stated above!
Thanks for the info guys , I heard the info I wanted to hear
Those dealer service manuals are priceless to have around . I'm too cheap to buy though , I always just check them out at the library when needed .
09-28-2015 12:51 PM
