2.0L Turbo >< 2.0L SC? Please discuss!
#51
Originally Posted by -Jayson-
insruance companies dont look at HP when rating a car. They look at safetly, theift rate, doors, year, mileage, value of the car, and reputation of the car (ie sports car, luxury car, Offroad. HP makes a very small percentage of what they charge for insurance, atleast untill you get above 300HP mark. At our low level of HP, insurance companies dont really care.
#52
Originally Posted by cawpin
While you make a valid point the 1969 Chevelle was not "under rated" in displacement. Chevy made a slight change to the bore of the engine and it subsequently changed the displacement. They didn't feel like changing the name of the engine since it was so well known, and feared. It wasn't an under rating just a marketing choice.
#53
fella's....
I love my SC and i for one will not go away from that. I will however go to a biger blower and work it from there.
as for the turbo VS Sc debate that this willmost likly turn into...heres my thoughts.
first VVT on our motor its not needed...there very little if any benifit to cam phaseing(VVT) on blown aplications.
so to who ever said that "the power differance between the 2.0T over the 2.0SC is found in VVT and Direct injection" you are mostly wrong.
the direct injection in its self makes no power differance at all its the fact that it will allow more precise fuel control and the ability to run higher CR's that make the power...VVT is a very small part of that.
also in the end of the "big power" wars a turbo will always make more top end power...its as plane as the eff% of each power adder the turbo is usealy aobut 12%+ more eff.
but i love the INSTANT TQ and power from the SC...the wine is a plus.
a BOV would be cool but i can atest that ya'll will most likly be unimpressed with the sky turbo's and such 2.0T cars...at least in factory trim.
from past exsperances and waching people race while I was chillin at woodward I've seen this "superior" engine fall to the hands of a farily stock SS/SC...i have raped one.
all and all its a simple fact of "to each there own" some will love and want the turbo while a few of us will contine to push the m62 and what ever blower comes next to the limits...and i'm sure in the comeing years there will be plenty of of "kills" and "killed" between the 2.0T cars and the 2.0SC cars.
how ever i do not think that the high performace aftermarket will catch up to the 2.0T engine for a few years...performance tuning on a DI(direct injection) car is much more complicated then our set up...a simple flow rate conversion and differant injecters can solve many of our fuel issues how ever on a DI set up its not quite that easy.
normaly injecters cant and dont need to be swaped due to there HUGE fuel pressure abilitys but theres much tuneing to be done on such a fuel system becasue not only to do have to control flow rates you must also command diferant fuel pressures at the same time...and this must stay consistant and flaw-less in the entire rev range.
thats what i think.
thats what i think.
#54
#55
Originally Posted by mi6_
Also for thos claiming the axles can't hadle the power, most of the people I have seen who have snapped an axle did it on a non-G85 car. The LSD saves driveshafts. Non-LSD equipped cars are not meant for track use. The car would be fine with the 2.0L turbo as long as the LSD is included.
Yeah, except, no.
I snapped two half shafts, on two separate occasions in my G85 Cobalt.
You sir, need to quit pulling things out of your, ahem, behind.
#56
1) Neon SRT-4 (230 HP/ 250 lb-ft)
2) Caliber SRT-4 (300 HP/260 lb-ft)
3) Mazdaspeed 3 (263 HP/280 lb-ft)
There are three FWD cars in the same class as the Cobalt all producing at least 250 lb-ft of torque. If these cars can handle it, why couldn't the Cobalt?
#57
Originally Posted by CobaltSonOfS.A.M.
But it IS a altered dyno readout, how much nobody knows. Car companies have been under rating car for decades, the 69 Chevelle SS 396 was even under rated on displacement, it was actually a 402. Look at the 02 Skyline GTR, Nissan said it had 285hp, but they have been chassis dyno'd at 350+hp stock. Thats with the AWD soaking up some HP too. Car company's do this for many differant reasons.
first of all there was no 2002 gtr, it stopped production in 2001 and it actually had around 320 hp at the flywheel stock. if it put down 350awhp stock it would be a low 12 second car stock.
#58
so if gm built a super safe, 300hp 2000lb monster with the best anti-theft system there is, it would cost 5 bucks a month? I don't think so.
#59
Originally Posted by tube
Yeah, except, no.
I should have said it helps save axles in certain situations.
