2.85 with stage 2
2.85 with stage 2
i just ordered a 2.85 pully from nates. i have heard that alot of people are running them with stage two tune. my mods are cai, megan exhaust, catless dp. stage 2, colder plugs ( bkr7e). will i be good running this set up. i dont beat on my car two often just normal driving
so, no opinions?
so, no opinions?
Im running 2.8.. im doing fine..
look at it like this...
stage 2 tune is very rich, pushing more air into the engine (smaller pulley) will lean out the AFR, thus making less stress on your injectors (cause they dont need to use as much fuel)... get it?
About the cooling mods... id say it would be safe to get the 2.8... and just dont "race" it every second... do a run or two.. let cool (dont turn off the car though)... keep driving... couple runs.. give break... so on..
True... for some reason i completely forgot that it did that... Sorry...
But for the most part... if you got your car tuned... you can do as i stated and get a little more security out of it..
so, no opinions?
so, no opinions?
Disclaimer: I ran a 2.8 on a daily driver for a year and a half without any problems. I run a 2.9 now.
what are temps suposed to be with a stage 2? temp down here is like 98 daily so my temps stay at like 185 while driving and higher in traffic
so do yall think they temp are good? or bad? maybe i should wait to put it on when it gets colder
Haz l33t wheelz.
please get 60's to be safe. and cooling mods are a must if you want your car to last.
that number is you engine coolant, your IAT's are probably pretty high, especially on just the stock H/E
get a CX H/E and 60's, tune and you'll be set.
Haz l33t wheelz.
personally, i'm a firm believer in doing each step as a unit, and not installing stuff until every part of the upgrade is ready. you are pushing you injectors right now, but as long as you don't get on it hard , you should be ok.
