2.9 boost problem
Old 04-13-2012, 11:02 PM
duffman11's Avatar
2.9 boost problem
I'm making only ~13 - 14 psi of boost at WOT witha 2.9 pully I thought I should be making at least 15 closer to 16
Old 04-13-2012, 11:12 PM
Got Bewst?
Bluelightning's Avatar
Boost is only a measurement of restriction. More boost doesn't always mean more power. You are right around where you should be with a 2.9"
Old 04-13-2012, 11:25 PM
YelCal7's Avatar
I am on 2.9 and I am only seeing 13-14 top. I never seen my car go 15-16 if I want to go 15-16 then I would had 2.8 pulley.
Old 04-13-2012, 11:26 PM
YelCal7's Avatar
My opinions 2.9 is good enough and will be switching 42lbs to 50lbs will be better.
Old 04-13-2012, 11:58 PM
nhanson's Avatar
might see 15+ with cold weather but probably not anymore.
Old 04-14-2012, 10:34 AM
robd53's Avatar
I see 14-15 psi peak on my 2.9.
Old 04-14-2012, 11:02 AM
sick CCSS's Avatar
as said before, more boost does not mean more power, when creating more boost, its making the s/c work harder to force more air in since there is a greater preasure pushing back. im on a 2.7 and see 16 psi. i just love the torque
Old 04-14-2012, 11:18 AM
13-14 sounds right for a 2.9
im on 2.8 60s seeing 15-15.5lbs and around 16lbs in the crisp cold time
Old 04-14-2012, 11:42 AM
insylem's Avatar
On the street I only see up to about 14 psi boost, on the dyno I get 16, and on the track I boost to 18.
I have a 2.85"
Maybe theres something in the tune thats lmiting your boost though?
Old 04-14-2012, 01:49 PM
Got Bewst?
I have a 2.85"
Your boost equations make no sense
Old 04-14-2012, 02:40 PM
insylem's Avatar
Thats because they are not equasions.....
On the street Im more limited to how much I feel comforatable opening up my car.
By the time I top out 2nd gear, I'm @ 70mph.... SO I max out boost at like
14 maybe 15psi by then.
On the track, being a safer enviroment to accelerate your car, I dont have to watch for animals cops other traffic, I set up my interceptor to record boost, and I finished at the top of 3rd gear, at 100mph... 100mph has more drag then at 70mph and because of the diffrent gear ration between 2nd and 3rd, the engine had to work harder at 6000 - 7000 rpm in 3rd then it did in 2nd, thus more restruction on the engine and I peaked at 18 psi boost..
On the dyno, there is no aerodynamic drag, and itwas done in 4th gear, I maxed out boost at 16psi.
BTW: Before I installed my header Dyno Boost = 17, WHP = 232, after Dyno Boost = 16 and WHP = 239
More boost does not always mean more power, however when an engine is being compared to itself at the same RPM, then boost CAN be used to gauge power.
Old 04-14-2012, 03:17 PM
Vander Nars's Avatar
Im pretty sure our cars boost the same psi reguardless of dyno/track/street.
Old 04-14-2012, 08:15 PM
Got Bewst?
They sure do. I make 19psi with my 2.6" and can hit it in any gear regardless of where I am.
Old 04-14-2012, 08:19 PM
Got Bewst?
They sure do. I make 19psi with my 2.6" and can hit it in any gear street, dyno or track.
Old 04-14-2012, 08:24 PM
zerosk8ter83's Avatar
I have the promblem. My 2.9 was only making 10
Old 04-14-2012, 08:29 PM
Got Bewst?
What were you making on your stock pulley?
Old 04-14-2012, 08:36 PM
I was never on the stock pulley,I went straight to the 2.9
Old 04-14-2012, 08:55 PM
Got Bewst?
Ahhhh you're an ls. I never saw that the first time. Bypass valve isn't working properly?
Old 04-14-2012, 09:07 PM
It was brand new from zzp
Old 04-14-2012, 09:20 PM
what are your mods?
what type of tune do u have?
Old 04-14-2012, 09:28 PM
The tune doesnt control boost levels on a sc so thats out.I was on stock header and dp with a 2.5 catback.My guess it would be the dp since its very restrictive
Old 04-14-2012, 09:48 PM
duffman11's Avatar
Trifecta tune
Injen intake, Vibrant header / DP and GMPP exhaust 50# and 2.9
Old 04-14-2012, 10:37 PM
CobaltSS 16's Avatar
hmm that does seem low.. im at about 16-17psi on a 2.8 - 3" intake, full exhaust, and full cooling mods with custom tune.
Old 04-14-2012, 11:45 PM
the tune can control boost, by limiting it. my 1st gear is set at 10lbs and 2-5 is 15-16lbs
but @ZeroSk8ter83 the stock header/dp is what is restricting ya so you right big guy
Old 04-15-2012, 11:19 AM
Got Bewst?
If the stock header/dp was restricting flow you would see higher boost numbers not lower.
Quick Reply: 2.9 boost problem
