2.9 pulley
Yeah I know that, but how do you get the 3.34" pulley off? I'm a 2.4 s/c. Forgive my M62 ignorance, I never paid attention to the 2.0 threads until recently. Do you need a new hub to get the 2.8 to fit?
#42
Yeah, Im from Charleston SC, so pretty much sea-level here and on cold nights, i've seen 16.5-17psi on stage 2 only, but as everyone says, depends on a lot of variables.
#45
sorry guys i'm a little car dumb, to swap from stage 2 to 2.9 i need to take the belt off.
where is the belt tensioner located?. i asume i would have to lossen it to pull the belt right?.
#46
#48
#49
Yes you must take the belt off, the tensioner is right next to it looks like a little shock absorber with a pulley on it, a little notch next to it 15mm wrench push it back towards the firewall!
#50
Rent me! per hour
then when the wrench slips and you smash your hand into the valve cover a couple times. you will remember to do it slow, and put a rag ontop of the wrench to soak up the blood that is now oozing from your knuckles.
