2.9 pulley
#53
The stage 2 package comes with a special Bit from GM. That's what you'll need for the blue s2 bolts. Contrary to the belief that you can get them off with other tools, try to stick with that GM tool as its the one made for the bit and stripping those screws is gonna suck big time.
#54
Put a prybar between the S/C pulley and tensioner and SLOWLY push it down. When its all the way down, put a 5mm allen key in between the tensioner and the engine lift bracket. Will hold it in place, and no busted knuckles.
#56
maybe its time to think about something more freer flowing? If you're running off the stock boost gauge that might be showing a little higher than normal sometimes, my interceptor seems to run lower than when i had my stock boost gauge. If this snow would stop i might actually take my car out and get some of my own number
#58
i dont really care to have an aftermarket exhaust.. though i know i should get one.. i can't stand the weed whacker sound..
